TNT25169's Avatar
Send a message via AIM to TNT25169
924S Speedo works but odometer doesn't
I think the title is pretty self-expanitory but more in depth....I have a 924S speedometer that works but the odometer and tripometer don't work. Is there anything that can be done to fix this? The speedo is currently out of the car. Thanks.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 08-07-2007, 07:41 PM
winter-hater club member
nynor's Avatar
the gear is broken/stripped, or has slid down on its axle (or whatever you want to call it). they can be repaired. do a search for extensive information about this.
i repaired the odometer several times on my '83 and found every time that the gear had slid. moving it back and putting a spot of superglue on it would work temporarily. i ended up replacing it, eventually.
"COOL PRIUS!" - Nobody Ever
Old 08-07-2007, 08:49 PM
Misunderstood User
Yep it's the gear. Never reset the trip odometer when the car is moving.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-08-2007, 04:23 AM
