924S Speedo works but odometer doesn't
I think the title is pretty self-expanitory but more in depth....I have a 924S speedometer that works but the odometer and tripometer don't work. Is there anything that can be done to fix this? The speedo is currently out of the car. Thanks.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
winter-hater club member
the gear is broken/stripped, or has slid down on its axle (or whatever you want to call it). they can be repaired. do a search for extensive information about this.
i repaired the odometer several times on my '83 and found every time that the gear had slid. moving it back and putting a spot of superglue on it would work temporarily. i ended up replacing it, eventually.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Misunderstood User
Yep it's the gear. Never reset the trip odometer when the car is moving.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Thread Tools | |
Rate This Thread | |
