Non Compos Mentis
How easy to put an "S" engine in an NA?
I have an '87 944 sitting in storage, and an engine from an '87 S.
How easy of a swap is it to stick the twin-cam engine in the NA? How similar are the electrical systems? Any other parts I would need? I got rid of the wrecked S quite a while ago. I have nothing left of it except the engine, and a few minor bits and pieces.
Thanks.
Old 08-27-2007, 11:16 AM
Cars & Coffee Killer
legion's Avatar
Do you have an 'S' DME, wiring harness, and AFM?
5 liters of VVT fury now
-Chris
Old 08-27-2007, 11:23 AM
Schumi's Avatar
You will need the wiring harness and the DME along with the AFM and airbox. The engine mounts are the same, everything is a direct bolt in I believe. Rerouting the wiring will probably be the second biggest pain behind getting the engine in the car (either top down up bottom up, both can be done)
M
Old 08-27-2007, 12:03 PM
meister member
speedracing944's Avatar
contact ilikemy944. He did the swap and reported the car was a blast to drive.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-27-2007, 04:52 PM
Non Compos Mentis
I'm pretty sure I've got the DME box sitting on a shelf, but I'll have to look for the AFM. I removed the intake manifold from the engine quite a while ago, but should still have the AFM somewhere. The airbox was destroyed in the accident, but this will be a race car project, so an aftermarket intake would be part of the plan.
Thanks.
Old 08-27-2007, 05:13 PM
gtroth's Avatar
--not sure the exaust will bolt right up.
S clutch and trans are uprated to handle the extra power too, I believe.
1995 993C4 guards red
1988 944S alpine white
Old 08-27-2007, 05:39 PM
aribop's Avatar
You will also need the engine compartment wiring harness. The 'S' has an ignition module mounted in the driver side fender beside the A/C accumulator and a series resistor for the injectors mounted on the passenger side fender beside the cruise control motor.
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 08-27-2007, 07:58 PM
legion's Avatar
The exhaust most definitely will not bolt right up. I tried. It was very, very close, but one bracket is slightly off or the pipes are 1/4" different in diameter or something that is hard to detect.
I think the clutch is the same between an 'S' and NA. I had the POS rubber center bit.
The tranny is slightly different, but it has 20 more HP on a good day, and only above 5,000 rpm, and worse low-end torque.
I wouldn't worry too much about the tranny...
-Chris
Old 08-27-2007, 08:12 PM
adrian1's Avatar
I have a wiring harness for a S if your interested, i bought it back in day for my 97 944 s before i had an accident and never used it. I payed a $100 for it. i sell it for something like that....I think it comes complete
1986 PORSCHE 951 3.0 project has begun!
1989 IROC-Z(Show Car)
1961 Willys Jeep w/ 283 chevy(straight open headers)
1995 Dodge Ram 2500 HD
1981 Corvette 4spd
Old 08-27-2007, 09:10 PM
martin944's Avatar
i have an S, and yes the low end torque is nothing to write home about. the fun starts after 4k rpm.
Old 08-28-2007, 07:05 AM
Non Compos Mentis
This will be a race car. I'm looking for a bit more high-rpm power. Adrian, thanks for the offer- Next time I'm out where I've got the cars stored, I'll look and see if I've got the wiring harness. Probably not, so I may take you up on your offer.
Exhaust won't be an issue. The car will get a header and 3" exhaust.
If I've got all the pieces I need, I think it's time to strip the car down and install a cage while we go through the engine and add new bearings and the oil upgrades.
Thanks.
Old 08-28-2007, 12:57 PM
