Front end question '84 944
Every time I hit a good bump in the road, my front wheels feel like they
bounce several times and the car briefly wanders for a second or two. Car does track nice and straight otherwise. Are the front struts gone or is it the steering
rack. How do I check it out myself.
Old 09-06-2007, 12:31 PM
Custom User Title
Dave L's Avatar
sounds like struts to me, I would look for leaks and do a "bounce test" although I though my shocks were fine until I upgraded to Konis. How many Km's on the car?
Old 09-06-2007, 02:15 PM
struts
180,000 kms suspension is very firm no leaks on inspection.
Old 09-06-2007, 02:18 PM
Gon fix it with me hammer
svandamme's Avatar
the control arm ball joints, or bushings perhaps??
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-06-2007, 02:33 PM
earlr85944's Avatar
check for leaks at the front struts and bounce the front suspension:
lift the front end off the ground and use a pin to lock the rack in place or have
someone hold the steering wheel and check for play in all mechanical wear areas by moving each wheel left to right and observing play in;
steering shaft links, tie rods inner (mostly) and outer,
ball joints - put a bar under the wheel and try to lift it;, and for bearings grab wheel from top to bottom and try to tilt it in and out;
change all found questionable, then get an alignment
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 09-06-2007, 04:09 PM
