ronined's Avatar
Upper radiator hose split
I have an '87 924S. I was driving home tonight and noticed that my temperature gauge was reading a bit high. Unfortunately, I was stopped by a train and the temp needle made it just into the orange zone. After the train passed I was able to nurse it back home with the gauge reading between the last white dash and the orange area. I got home and noticed that the upper radiator hose had split and was leaking a steady little stream of coolant. The drive home was about 20 minutes with the ambient temperature in the low 60s F and speeds around 45mph, at most. Other than the obvious new hoses, coolant, and bleed, do I need to be concerned that more extensive damage may have occurred?
TIA
Ed
'87 924S
Old 10-19-2007, 08:29 PM
Eldorado's Avatar
not really... I Dont think..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 10-19-2007, 08:30 PM
ronined's Avatar
Investigated a little further and noticed that the radiator is loose at the top. Apparently, it flopped backwards and the pulley that lives right behind it rubbed through the upper rad hose. So now I got to fix the "floppy" radiator, too!
Ed
'87 924S
Old 10-19-2007, 08:46 PM
The clip that stops the top hose doing that is missing.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-19-2007, 09:35 PM
Redline Racer
HondaDustR's Avatar
There's a clip that holds the hose? I've killed a hose and limped home (without any overheating, luckily) the same way, and almost buzzed through the new one, too. My radiator mounts were all screwed up, though. The PO must have run it up onto something and knocked 'em crooked. Straightened up, there is plenty of clearance. The hose also goes on a particular direction that's not very obvious. It might make the problem worse by installing it backwards.
Hmm, this seems like one of those "who hasn't done it yet" kind of things on these cars. Kind of tricky.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 10-20-2007, 06:00 PM
ronined's Avatar
Am I missing a bracket that should mount on those three studs inside the green circle and keep the hose in place?
Ed
'87 924S
Old 10-21-2007, 05:33 PM
Redline Racer
HondaDustR's Avatar
That is actually a bracket that is also bolted to the airbox to stabilize it. Maybe there's a hose retaining clip that attaches to it, but if there is, then mine is missing.
Old 10-21-2007, 06:14 PM
ronined's Avatar
Would someone mind posting a picture of what is supposed to go there? This is the area between the left headlight and the catch for the hood.
Ed
'87 924S
Old 10-21-2007, 06:23 PM
