Gremlin85's Avatar
Send a message via AIM to Gremlin85 Send a message via Yahoo to Gremlin85
Question Bottom End Rebuild
I'm going to start rebuilding my bottom end in my 87 944.
Long story short... I got rod knock at start-up a couple months ago and parked it since.
I'm gonna need a set of crank bearings AND rod bearings, correct?
After this its for sale.
Any suggestions? Pointers? Tips?
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN.
2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance.
Old 10-18-2007, 02:19 PM
Back from Beyond
If you had knock you're probably already too late and the crank's scored. Gotta pull the motor.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 10-18-2007, 02:42 PM
Gremlin85's Avatar
I'll probably tear it apart this weekend and send the crank out to be polished and measured. Once I get the results I'll order bearings.
I've only had the thing for 9 months.
Old 10-18-2007, 06:44 PM
Back from Beyond
Make sure your machine shop knows what it's doing. There are only two bearing sizes - standard and 1st oversize. It may be a good idea to get a good used crank from someone on the board, but I don't know how much machining yours would cost.
BTW, given your description your car looks pretty good. I like the grey/burgundy combo.
Good luck!
All others GONE!
Old 10-18-2007, 08:01 PM
Gremlin85's Avatar
I loved the Gray Burgandy combo. I knew I had to have it once I saw it. Everything seemed good and well taken care of. I guess somewhere along the line someone might have ran it low on oil for a while and then it got to me and I had to deal with the conciquences.
-John
Old 10-19-2007, 06:23 AM
Gremlin85's Avatar
just a second thought that i'm cross posting from rennlist...
anyone wanna take this off my hands for a fair price?
Old 10-19-2007, 10:59 PM
Sorry to hear it's rebuild time. I'd have the whole engine blasted clean as metal shavings go and hide everywhere. You'll most likely go .25 mm undersized (one size) for Rod Bearing while Main bearings will probably replace at standard size.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 10-21-2007, 06:16 PM
