OPRV questions
hey guys, Im trying to find out a little more info on the different types of OPRV (oil pressure relief valves) I belive my 1987 924S has the older one peace kind. I just picked up a 951 oil cooler housing that came with (what I believe to be) A 3 peace oprv, but Im not sure if its complete, Its just a small piston and a spring and a screw on cap at the other end. Is this correct??? DOes anyone have pics of the differnt OPRVs?? The one in my 924S works fine but if the one for the 951 is better I will use it. Just tryin to figure out if its all there. Thanx guys, anyhelp would ROCK
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
Nobody Special
This may help, sorry but I don't have a pic of the 3-piece style when I posted this on another forum. The difference in the two types of 1-piece OPRV's are the length and placement of the end O-ring. They have to match the housing style. The 86 951 is the only 951 that used the conversion 1-piece, 87+ were all the later style.
http://951forums.com/forums/index.php?topic=120.msg3378#new
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
So wait are you sating I wont be able to use my 87 924S oprv if I needed?? I thought they all work, doent matter the year. Tom I will post some pics of the 2 oprv's I have, Thanx for that info
You need to use the OPRV that matches your block year. In your case, the 87+ one peice OPRV. AFAIK, The covers are the same so you can use the 951 cover with the 87+ block and OPRV.
1986 951 |
Nobody Special
Edit: Good news, it looks like you can still use your later 924S OPRV even in an early 951 oil cooler housing on the later blocks. The 86 and 87 951 oil cooler (thermostat housing) are the same part number which means just the OPRV is different due to changes in the block design. I'm still looking for that other info I have, bear with me!
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD Last edited by 2Tight; 10-25-2007 at 07:56 PM.. |
COOl, thanx for the info. I gotta get to the garage and remove my oprv to take pictures. SO proly saterday. Im using a 1987 block and oprv in a 1986 951 oil cooler housing just to claer things up. Again thanx for all the help/info
