Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Question Another?
How does the cam belt going over the WP appear on your car? Is it steady or does it vibrate? The portion after the WP to the cam gear is the area I question.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 10-25-2007, 07:22 AM
Pretty steady on mine. Make sure that the drive gear on the crankshaft has the lip towards the front of the car. If not, the timing belt can slide forward and this can cause it to misalign on the cam gear. Also make sure you have tightened the nuts on the spring tensioner (All 3 mounts and both tensioner release nuts.)
John
1987 924S PCA Class I
Old 10-25-2007, 08:22 AM
924Sman's Avatar
I must have had some slack as it is ok now. How I do not know but seems fine now. Thanks John
Dal
Old 10-25-2007, 11:22 AM
