Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Question Bad memory...What is this again?
The sensor near the blue temp sensor that has one wire and spade. I forgot what is is for. Turbos have this sender but w/2 spade. IIRC brown/black stripe. On a 87 na
tia
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 10-25-2007, 06:27 AM
924Sman's Avatar
Never mind I figured it out....coolant temp. Now if it is bad/disconnected what symptoms arise?
Dal
Old 10-25-2007, 06:47 AM
Politically Incorrect
onZedge's Avatar
Are you sensing a problem?
The sensor you describe is for the temperature gauge only. The gauge should read minimum temperature if it is disconnected. The sensor with the blue plug is for the DME only.
Edek
'87 924S
'91 535i
Old 10-25-2007, 09:26 AM
924Sman's Avatar
Good it works then. It has a brittle wire and I heard a snap/crack but it is running the gauge as per spec. Thanks Edek
Dal
Old 10-25-2007, 11:24 AM
