What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
update on cooling problem
This is an update on my cooling problem.
When I initially replaced my thermo switch, I also replaced my 3 blade fan with a 6 bladed one.
What I didn't notice is that I had switched the positive for the ground, making the fan run in reverse. This in turn caused no fanning of the radiator. So if you still have a problem with non cooling , you might want to verify the polarity of the electrical lines to the fans. In the early 944, there is no "plug" for the 3 bladed fan, just a positive and ground wire that slip on.
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 11-08-2007, 04:42 AM
Nobody Special
You mean the single 3-blade early fans didn't have a hard plug for the motor? I swapped my double 3-blade unit for a double 6-blade. Except for the connectors being straight rather than right angled there is no way to reverse polarity unless you cut wires. Having the fans pushing would certainly cause some issues for sure.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 11-08-2007, 07:11 AM
The 6 bladed fan has a nice plug-in connector. Both of my 3 bladed fans have only two terminals that will take the cables a certain way ( one large, one small) but will fit on the 6 bladed fan at either side of the plug-in connector ( connectors being oversize for both sides of the plug-in).
3-924's (Sold)
1967-912 (Traded)
Old 11-08-2007, 07:21 AM
Nobody Special
I must have had a later 83 because mine had plugs that swapped perfectly (except the angle vs. straight) and there was a guide ridge on the plug to insure correct polarity. I also had factory power steering so maybe some changes were made in mid model year.
Old 11-08-2007, 07:29 AM
bearone2's Avatar
the old '84na had the single plug for each fan, which could go either way, affecting rotation of the fan.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 11-08-2007, 12:06 PM
