Removing all a/c components
The a/c compressor on my 87 n/a is broken, one of the tabs is broken off, i dont use the a/c anyway, and the hoods off anyway, so im going to reomve all a/c components.
First and most importantly, does this pose any problems to anythign whatsoever, thanks josh
1987 944 n/a |
You need to get an A/C delete bracket to put back in...
-Randy 1984 944 -Race car project 1993 968 coupe- Amazon Green |
Will work for parts
I have heard of a way that you just use a short belt and don't relocate the Alt. I am just unsure of the method of tensioning.
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
Redline Racer
I'm curious if there's a way to do that as well, since I'd rather keep my alternator up high and out of the water when it rains.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Politically Incorrect
The only way to adjust the accessory belt tension is a turnbuckle attached to the A/C compressor. If you remove the A/C compressor, you have to relocate the alternator with an A/C delete kit so you can adjust the belt tension. On cars with A/C, the alternator is hard bolted to the block and has no means of adjusting accessory belt tension.
Edek '87 924S '91 535i |
Cars & Coffee Killer
I did this over a year ago. I'm glad I did. The alternator is much cooler (instead of snug up against the turbo). I also get better airflow through the radiator without the condenser.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Redline Racer
![]() My condenser sacrificed itself to leave my radiator remarkably unharmed after I ran it off the road and up onto a rocky slope...knocked the rad clean out of it's mounts, potatochiped the condensor, knocked the power steering belt out of whack, broke the rad fan housing, totally clobbered the front valence, and blew a tire. It was pure stupidity on my part, cranking around a hard left in low second WOT, understeered into some gravel on the side of the road...and snap! That was months ago, though, but I'm all the wiser now...and incredibly lucky that my car doesn't look like anyone did something stupid with it.
Who all sells the AC delete bracket?
Dave 82 928 Weissach #14 |
There is a Porsche-made one. Pelican will have it.
There are also several aftermarket brackets. I have the one from Lindsey Racing.
Thread Tools | |
Rate This Thread | |
