I think I owe you an apology and I didn't intend to come across like it did. Yes you are entitled to your opinion like all of us. I don't want to argue with you because that's something old men like me try to avoid. As far as shortcuts or improvements over the FSM I can only add a few that I'm hoping you won't find insane or dangerous. The FSM has you drop the cross member and disconnect the steering knuckle to change motor mounts; it's easier and faster to loosen the X-member, raise the engine some, and do one side at a time to keep the engine from shifting side to side similar to Clarks method. Another is changing a broken door handle from the outside by removing the roll pin on the drop piece. I'm no genius but if someone shows me a better method to do something I'm willing to at least listen and judge for myself. Again my apologies if I came across other than just trying to give the poster another option used by countless people. I had no call to question your comments or reasoning and should have just let them go. Peace |
No apology required. I think we old men got caught up in arguing opinions instead of offering advice to the person who started this thread in the first place.
I gave up and took mine to a shop. I installed the rear shocks (Bilstein) myself, but the struts proved to be an issue. For one, that top locknut is a *****. Two, who has a spanner wrench? Three, the spring is a crazy issue. And four, I wanted the alignment done at the same time.
I used an impact wrench also. I used a pipe wrench to open the cartridge. I don't want to bring up old stuff here but, to me, it it much easier to totally remove the strut to work on than leaving it on the car. I took my strut assemblies to my nieghborhood High School auto shop to get the springs removed. They had a very nice spring compressor device that was sturdy and safe.
After cleaning and painting the struts, I went back to reassemble them. |
I know you can buy a special tool, I believe for about $20 that is designed to remove the top nut of the strut. Rather than spending the money on the tool, I did some research and found that an impact wrench can essentially do the same thing in most cases. The pipe wrench was suggested by the auto shop teacher. Actually, I used 2 of them One to hold the cartridge, the other to loosen the cap.
It's funny but I did the same thing 2Tight did to tighten the nut. I didn't use security nuts but full nuts and lock washers. I guess great minds think alike........maybe not. |
| All times are GMT -8. The time now is 04:55 AM. |
