Replacing front struts..... myself
I have all the components to rebuild my front struts on my '84 944.
I have a very detailed dvd of the procedure step by step. This will be my first attempt. Any advise or tips from anyone who has done the job before. Thanks |
Struts on these cars are very straight forward.
I would loosen the top nut before you jack the car up, that way you dont need spring compressors. Other than that its a quick job. |
I did mine and it is fairly straight forward, I brought my whole strut assembly in to my mechanic and had him deal with the spring compressor fun. From what I have read you really dont want one of those cheap spring compressors to fail or slip off and send the spring flying. For a half hour labour charge I knew that it was done right and safely.
be sure to mark the eccentric bolts before disassembly so you can get the alignment "in the ball park", get an alignment a week or so after to ensure that the suspension has settled. |
Rent a good spring compressor. Then it's a safe and quick job. Do one side at a time so if you get confused you can look at the other side to see how it's supposed to be.
Good luck. Jon |
Since you have an early car you have it easy. You don't even have to remove the struts from the car, no spring compressor required, and your alignment isn't effected. Remove the strut shaft nut while the car is on the ground. Jack up the front, place on stands, remove wheels, disconnect the sway and drop links from the arm on both sides, press down on control arm with a leveraged bar and swing the strut outward to clear the upper mount and fender, remove the spring while still pushing down on the arm. Once the spring is off you can back off the top cap on the strut tube and remove the old insert. I always remove that nasty oil installed in the bottom of the tube and use new oil. Some people even make it easier by removing the top strut mount and dropping everything through the fender. I've always used the method I described for early cars. Last time I did both fronts in well under an hour.
That procedure is insane. You should never use the weight of the car as the "spring compressor".:eek: Use the correct tools for the job and the correct procedure according to the Factory Service Manual. An alignment will still have to be done regardless of the R&R method used. Again, my opinion. Do what you want. The link below my signature contains HD color pictures and comments as to R&R'ing front struts on a 924S. Same procedure as your '84 944. |
BTW: Nice write-up on your struts. I see why you removed everything so you could paint and install new strut towers. |
Was that rhetorical?
...and because the Factory Service Manual says so... |
Since the subject presents itself, I recently installed Koni's on my 85.5 944 using a spring compressor. All went well until the alignment tech said the springs were twisting in the spring seat. When I turned the steering wheel the springs would move in the seats and make a clung type of noise, as the bearing plate was hanging up and not allowing the upper spring seat to twist with the strut. When I reassembled I tightened the strut nut as directed to so-many ft-lbs. But the strut bearing plate could have also been replaced, apparently.
My temporary solution was to back off the strut nut a bit and install a second lock-nut to keep it from working free. I didn't trust the old nylon core original nut and the new Koni's came with a nut and lockwasher instead of the nylon do-dad. I am still not sure what I did wrong to make the springs twist. Did I overtighten the strut nut or is replacing the bearing plate essential or is there something else like a spacer I missed? Anyway, all is still OK with he lock-nut deal! |
He is free to do his any way he wants but stop saying our method is unsafe or not by the book; the FSM does all sorts of things the hard way and we improve upon them all the time. |
I am definately going to try the non-compressor method next time. Seems easier than gator wrestling a strut, especially if you don't have a vise.
Wait... I need to make more popcorn...
droplinks
What do you mean by "loosening the drop links at the arm" Do you mean
the the cam bolt and bolt beneath that? Thanks |
The only problem you might run into is that the insert retaining cap might be frozen. Mine was when I did mine. After much WD40, wrestling, pounding, fuming, ect. I eventually gave up and cut them off. Luckily the Bilstein inserts I got come with their own special retaining cap, so it didn't matter.
My strut spring compressor has locking pins that physically prevent the spring from slipping off the jaws in any way. But the shortcut mentioned sounds like a great idea...unless you have to cut the caps off. Good luck. :cool: |
What ever method you use to work on your car please understand the risks and take safety seriously. |
Fairly simple job. The are enough posts and information to help you. Hardest job is removing the springs. There are a number of options as many have posted. I used my local high school auto shop to remove and install my springs. Assembly is straight forward as well.
Good luck. |
| All times are GMT -8. The time now is 05:41 PM. |
