Exclamation Replacing front struts..... myself
I have all the components to rebuild my front struts on my '84 944.
I have a very detailed dvd of the procedure step by step. This will
be my first attempt. Any advise or tips from anyone who has done
the job before.
Old 11-23-2007, 05:36 AM
Struts on these cars are very straight forward.
I would loosen the top nut before you jack the car up, that way you dont need spring compressors. Other than that its a quick job.
Jason
88 924S SE
Old 11-23-2007, 05:54 AM
Custom User Title
Dave L's Avatar
I did mine and it is fairly straight forward, I brought my whole strut assembly in to my mechanic and had him deal with the spring compressor fun. From what I have read you really dont want one of those cheap spring compressors to fail or slip off and send the spring flying. For a half hour labour charge I knew that it was done right and safely.
be sure to mark the eccentric bolts before disassembly so you can get the alignment "in the ball park", get an alignment a week or so after to ensure that the suspension has settled.
Old 11-23-2007, 10:04 AM
Rent a good spring compressor. Then it's a safe and quick job. Do one side at a time so if you get confused you can look at the other side to see how it's supposed to be.
Good luck.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 11-23-2007, 01:22 PM
Nobody Special
Since you have an early car you have it easy. You don't even have to remove the struts from the car, no spring compressor required, and your alignment isn't effected. Remove the strut shaft nut while the car is on the ground. Jack up the front, place on stands, remove wheels, disconnect the sway and drop links from the arm on both sides, press down on control arm with a leveraged bar and swing the strut outward to clear the upper mount and fender, remove the spring while still pushing down on the arm. Once the spring is off you can back off the top cap on the strut tube and remove the old insert. I always remove that nasty oil installed in the bottom of the tube and use new oil. Some people even make it easier by removing the top strut mount and dropping everything through the fender. I've always used the method I described for early cars. Last time I did both fronts in well under an hour.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 11-23-2007, 01:43 PM
Politically Incorrect
onZedge's Avatar
Originally Posted by 2Tight View Post
...You don't even have to remove the struts from the car, no spring compressor required, and your alignment isn't effected...
Since I am entitled to my opinion:
That procedure is insane. You should never use the weight of the car as the "spring compressor". Use the correct tools for the job and the correct procedure according to the Factory Service Manual. An alignment will still have to be done regardless of the R&R method used.
Again, my opinion. Do what you want.
The link below my signature contains HD color pictures and comments as to R&R'ing front struts on a 924S. Same procedure as your '84 944.
Edek
'87 924S
'91 535i
Old 11-23-2007, 04:48 PM
Nobody Special
I'm sorry you feel that way and you are entitled to your opinion. What you are saying is just plain untrue though. There is nothing insane or unsafe about it. The spring is compressed still when the strut shaft nut is removed. As the car is raised the the compression is slowly removed from the spring and it is loose on it's perch. The reason that the car does not have to be re-aligned is the lower bolts, eccentric included are never loosened. If you think using a spring compressor in the hands of a DIY garage mechanic is safer then you need to reevaluate your statement. Do you have any idea how many many people do it this way? There is absolutely no reason to remove the strut if your early car takes inserts. Unless you have replaced them yourself by this method your opinion is actually pretty comical to those of us that have done it several times and wish we had known about before going through your method the first few times. Don't knock what you haven't tried as I was told in the oil viscosity thread.
BTW: Nice write-up on your struts. I see why you removed everything so you could paint and install new strut towers.
Old 11-23-2007, 05:19 PM
Could you please explain how you formed this opinion? Whats the difference between using the car as your spring compressor or buying one? Ive done every suspension Ive ever replaced this way. I have a pair of spring compressors if I ever need them, but they just collect dust in the toolbox. I have a couple frieds that are techs at local shops, they use this method, its just that they never tell anyone because if something did happen and sopmeone said "so and so is an ASE tech and he said I could do this" they would probably sue them.
Jason
88 924S SE
Old 11-24-2007, 11:01 AM
onZedge's Avatar
Was that rhetorical?
Originally Posted by Jsilverman View Post
...Could you please explain how you formed this opinion?...
At first I wasn't going to reply, except I needed to point out that you already answered the above question below.
...its just that they never tell anyone because if something did happen and sopmeone said "so and so is an ASE tech and he said I could do this" they would probably sue them.
That being said, spring compressors positively restrain the springs - they come with directions for proper use. Unloading the springs using the car's weight will cause unexpected results if something were to hang up due to corrosion or other interference. Reloading the springs using the car's weight will have equally unexpected results if components are not perfectly lined up and may cause damage to the new part you are trying to replace the defective part with in the first place...
...and because the Factory Service Manual says so...
Edek
'87 924S
'91 535i
Old 11-24-2007, 11:34 AM
The first time I replaced the struts on my 924 I noticed that the springs were completely unloaded when I jacked the car up so I dont really see how there is any danger in simply removing the top nut that doesnt have any pressure on it from the springs.
Jason
88 924S SE
Old 11-24-2007, 01:31 PM
Since the subject presents itself, I recently installed Koni's on my 85.5 944 using a spring compressor. All went well until the alignment tech said the springs were twisting in the spring seat. When I turned the steering wheel the springs would move in the seats and make a clung type of noise, as the bearing plate was hanging up and not allowing the upper spring seat to twist with the strut. When I reassembled I tightened the strut nut as directed to so-many ft-lbs. But the strut bearing plate could have also been replaced, apparently.
My temporary solution was to back off the strut nut a bit and install a second lock-nut to keep it from working free. I didn't trust the old nylon core original nut and the new Koni's came with a nut and lockwasher instead of the nylon do-dad.
I am still not sure what I did wrong to make the springs twist. Did I overtighten the strut nut or is replacing the bearing plate essential or is there something else like a spacer I missed?
Anyway, all is still OK with he lock-nut deal!
Old 11-24-2007, 01:35 PM
Nobody Special
There is no danger, that's what I've been trying to get onZedge to understand. You do not need a spring compressor to do 944 struts especially if you disconnect the drop links at the arms. It's a hell of a lot safer than using a spring compressor with the strut mounted in a vise. I use my floor jack to control spring placement for reassembly. I have never had a spring installed wrong or spin yet using this method. I have seen people nearly lose a finger or eye using a spring compressor though. The only time this method might not work is if you were using full length #400 springs.
He is free to do his any way he wants but stop saying our method is unsafe or not by the book; the FSM does all sorts of things the hard way and we improve upon them all the time.
Old 11-24-2007, 02:14 PM
I am definately going to try the non-compressor method next time. Seems easier than gator wrestling a strut, especially if you don't have a vise.
Old 11-24-2007, 02:39 PM
What springs are you using? OEM or aftermarket?
Jason
88 924S SE
Old 11-24-2007, 05:19 PM
onZedge's Avatar
Wait... I need to make more popcorn...
...but stop saying our method is unsafe or not by the book...
Hmm. Did somebody repeal the First Amendment when I wasn't looking?
...the FSM does all sorts of things the hard way and we improve upon them all the time...
I'll call your bluff - cite some examples. (please remember that "improve upon" and "risky shortcuts" are two completely different concepts)
Edek
'87 924S
'91 535i
Old 11-24-2007, 06:45 PM
droplinks
What do you mean by "loosening the drop links at the arm" Do you mean
the the cam bolt and bolt beneath that?
Old 11-24-2007, 07:16 PM
Redline Racer
HondaDustR's Avatar
The only problem you might run into is that the insert retaining cap might be frozen. Mine was when I did mine. After much WD40, wrestling, pounding, fuming, ect. I eventually gave up and cut them off. Luckily the Bilstein inserts I got come with their own special retaining cap, so it didn't matter.
My strut spring compressor has locking pins that physically prevent the spring from slipping off the jaws in any way. But the shortcut mentioned sounds like a great idea...unless you have to cut the caps off.
Good luck.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-24-2007, 07:23 PM
Nobody Special
It means to disconnect the droplink (connector) between the sway bar and the control arm at the control arm. This allows the control to swing freely when you push down on it with your foot or a lever to remove the spring. Do not loosen or remove the two bolts holding the strut to the spindle unless you are removing the whole strut for replacement, painting, etc. It's really quite easy.
Old 11-25-2007, 07:15 AM
Custom User Title
Dave L's Avatar
I think the recent write up in Nine magazine on how to change the torsion bars is a good candidate. Instructing you to drill a 3 inch hole in the rear fender seems like an "improved" method
What ever method you use to work on your car please understand the risks and take safety seriously.
Old 11-25-2007, 10:11 AM
Misunderstood User
Fairly simple job. The are enough posts and information to help you. Hardest job is removing the springs. There are a number of options as many have posted. I used my local high school auto shop to remove and install my springs. Assembly is straight forward as well.
Good luck.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 11-25-2007, 11:32 AM
