944S timing belt problems and making the automatic shift higher &faster
Hi there,
You might remember me from before where I was going to convert my '88 944S to a callaway turbo:
Need Callaway turbo kit installation manual (for my 944S Automatic)
Well I sold off the turbo parts after deciding it was to much of a project for my high school advanced shop class. Besides my 944S needed a lot of maintenace!
My grandpa bought it new and it had 90,000 miles when Igot it and the timing belt was never changed. I changed it in my first quarter in shop class...the belt was rotten and had a couple belt teeth missing! Good thing I changed it in time. After I put the timing belt back on the engine vibrates a lot more now. Maybe I didn't get the timing belt back on right and its misfiring. It seems to have good power still...I'll figure whats wrong out next quarter. I need to take the belt off again anyway as the water pump is leaking now.
Also next quarter I want to rebuild the automatic transmission. I have to shift myself thru L-2-D to get decent power from the car...it shifts by itself at 4000RPM even if you floor it! The transmission is slipping now and it needs rebuilt according to my shop teacher.
My car has the "S" package with 16 valves and has no power on the low end. How can I adjust the transmission to shift at a higher RPM on its own? Also, is there a "shift kit" for this transmission so it shifts harder? Right now it really sliiiiiii...des into each gear. The shop teacher has a 2002 Camaro with a shift kit and it barks the tires when it shifts!
Thanks for any help or ideas. Pablo
Old 12-10-2007, 03:18 PM
Very strange.
Your 944S should not have come with an automatic transmission, as that was not available on that car.
All 944S, 944S2 and 944 Turbo cars came with manual transmissions only.
Good luck, George Beuselinck
Old 12-10-2007, 03:41 PM
Well my grandfather said he had to special order it that way because of his bad left knee and that no dealers had one in stock. When I looked up the value on the kelley blue book site it gave the option for an automatic. I don't think it was modified...my grandfather picked it up at the factory in Germany!
Old 12-11-2007, 12:44 PM
How about a picture of the engine bay, or your VIN number???
Old 12-11-2007, 12:49 PM
Did you sell all of the callaway stuff? If not I'm interested in what you have left.
Old 12-13-2007, 01:35 PM
Mein Gott!
Panzer909's Avatar
Yeah thats extremely interesting about the automatic tranny in an "S".
Regardless, sounds like the new vibration is your balance belt being a bit off. Its extremely easy to get it misaligned while tightening it. The good news its an easy fix.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 12-14-2007, 06:35 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Or it could be the motor mounts. They are one of the things that are known to go bad around that milage.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 12-14-2007, 08:33 PM
Redline Racer
HondaDustR's Avatar
Yeah, I've heard the S is kind of gutless in the low end , at least compared to the 8 valve motor.
You probably wouldn't want too hard a shift, since the transaxles in these cars, except for maybe the turbo, are a bit fragile and will pop the final drive ring and pinion if harshly abused.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 12-15-2007, 04:22 PM
