winter-hater club member
installing valve seals
i will be pulling the valves tonight on the head i am installing. i will number them to be sure they go back in the right places.
i have new valve seals that came the gasket kit i purchased. how do i install new valve seals? remember, this is my first time doing this work and i am mechanically challenged...
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
There is actually a tool to install them - you can get similar results by ousing a small piece of PVC pipe.
Use a little oil on the seals to get them to slide. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
thanks, afjuvat
You can also use a 1/2 inch deep socket.........and just lightly tap them in........you will easily hear them bottoming out.
....and if by chance these are the stock valve guides (smooth) you should use an adhesive to hold them in.......I had to use loctite 514. If you have guides with the cutouts then its not a problem the guide will dig into the seal.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
What kind of adhesive should one use to hold new valve seals in place (if you have the older style guides). I see ae1969 used loctite, is this what is most commonly used ?
'05 M3 - Alpine White '88 924S - Black '91 318IS - Alpine White '88 Honda Hawk '75 Honda CB360 |
