One of these things is not like the others
Here is a reminder to get your belts changed and tensioned. The timing belt broke here and a valve smashed into a piston causing all sorts of chaos. The top of the piston is missing a chunk and has a hairline fracture across it while the bottom half broke into about a million peices inside the cylinder wall. Here are a few pics. of the bottom of the piston and the biggest chunk.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
ouch! How many miles was on the belt? I have about 25K on mine now and I's starting to thinking it's about time to change it.
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
I don't know, I got the engine from someone else with a broken belt.
I've seen several engines with broken belts but never one that bad. It usually just bends a valve. Good reminder though.
Rick, I think most here change belts around 30,000 or so and then retension after the first 2000 miles.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
When I removed the oil pan there were shards or piston on the top side of the oil pick-up. I knew that was a sign this was going to be ugly. At least now I have a paper weight and an anchor....
A little JB Weld and it'll be fine.
![]() I think 3yr/36k miles is pretty safe for a timing belt.
Dan Former owner of: '88 924LE (Luddite Edition) manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5 torsions, 931 valance and header panels, 6X16 Fuchs, lowered, etc, etc. |
Oh my!
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
I think its broken
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
She'll buff out....I think....I'm going to build a race motor for a 24hr race and I'm thinking I can save some serious weight if I can find 3 more just like it....
Nobody Special
Wow that's really ugly. The difference between a cast or forged piston is what breaks or bends first.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
not straight....
working in the garage
Wow, cool paper weight Jon, NA or Turbo?
Ouch... That takes the cake as the worst timing belt failure I've seen!
2006 Porsche Cayman S 2006 Lotus Exige (Sold) 1986 Porsche 944 (Sold) 1981 Porsche 931 (Wrecked) 1987 Porsche 944 (Sold) |
N/A...Hey Jeremy, you want this short block to work on? hehe.....
lol... Hey Jon, I think I'll wait till you have another one available.
Same here...never seen that but I have heard of it happening every now and then.
