Dtchy's Avatar
944 short shift issue
Hey all,
Yesterday I finally found the time to install my short shift kit that I picked up from Fleabay ($70, Deutsche Parts USA). It's the same system as the Schnell and mounts on the tranny.
However, after taking everything apart, the long shaft of the SSK would not slide in the shift rod (going to the lever) on the car. It was simply too big. I sanded it down and that seemed to work. However, while working on it, I noticed that the guide pin dimple was located at a farther distance from the end of the shaft than the OE, I'd say about 1/4". So If I would even get the shaft in the rod, I would never be able to screw the guide pin bolt back in, because the dimple in the SSK shaft will not line up with the hole in the shift rod (and CMIIW, but you can only slide in the shaft so much)... The 2 shafts (SSK and OE) do have the same length though... I'm thinking the dimple on the SSK is drilled in the wrong spot and should match the OE location.
The confusing story above probably only makes sense to some of you who worked on the linkage on the trans, but has anybody experienced the same thing with this kit?
I put all the stock stuff back on and worked an hour for nothing...Oh well, at least I tightened up the bolts. The shifter seems tighter than before...
Any ideas???
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 01-21-2008, 03:40 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
I have the weltmeister kit i believe(the more expensive version) and like it alot. My dad got the schnell kit and it never felt as good, but installed fine. If I were you I would make a jig and re drill the dimple on the ssk. Sounds like they diddn't put much effort into the construction of these kits. Make sure you locktite everything because bolts backing out are not fun to deal with (trust me ;-) ).
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 01-21-2008, 04:32 PM
That Guy
Techno Duck's Avatar
Redrill the dimple. Ive read quiet a few posts over the last few months with fitment issues regarding the Schnell linkages. All of them mentioned the shaft being to large to fit into the main shift rod and it wouldnt surprise me if the dimples were in the wrong spot aswell.
All of these stories are one of the reasons i took my 944Racing shift linkage off my n/a before i sold it!
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-21-2008, 05:34 PM
shikzachaser's Avatar
The first Schnell I got also had the dimple in the wrong place causing there to be no way to shift into first or second. The replacement was fine. I also installed a Speedforce shortened shifter. The result of both is amazing. It literally has a throw that makes you not have to move your arm on the console. I have had them for about 5,000 miles over a year and a half and they work great together.
84 944 (my favorite all time car)
98 M3 (the wife's)
ML55AMG
03 Eurovan
00 Land Rover Disco II
Old 01-21-2008, 07:19 PM
Politically Incorrect
onZedge's Avatar
Vaht?
Originally Posted by Techno Duck View Post
...944Racing shift linkage...
Where can you get this locally. I went to their web site and all the vowels have oomlats and there is a generous use of the letter "z"...
Edek
'87 924S
'91 535i
Old 01-23-2008, 02:56 PM
That Guy
The 944Racing i am referring to went out of business around 4 or 5 years ago.
Jon
Old 01-23-2008, 03:09 PM
I got the Schnell from Eagleday.com They were great to work with. I called them when I realized that the set pin position (dimple) was in the wrong place. Apparantly Schnell had a batch that were welded w/ the hole in the wrong place. They sent one out next day. I bought the Speedforce one from Tim @ Speedforceracing (duhh). He is a good dude. They make their own to order and it takes a week or so. You have to use a Momo knob and cut the old boot from the OE shift knob. You put it on upside down w/ a black tie wrap and then turn the boot right side up to conceal the tie wrap. It works great, looks better, and reduces the throw about 40%. If I had to do one it would be the one at the shifter. With both the throw is incredible. The only negative is that by shortening the throw the effort is greater to shift. It's way worth it, especially since my wife no longer likes to drive it. "It's hard to shift, it's bumpy, does it need a muffler?" sweeet! Good luck with whatever you do.
I just ran out to the garage and tried to get a perspectiv of how the short shifter looks
It does ride rougher than when it was new, it's also a lot lower and has bigger tires and wheels
I never did get the supercharger I paid for but it still runs great. We did a couple pulls here at the Viper guru's dyno and it did right at 145 RWHP
There is still no replacement for displacement. This has kind of taken over as my hobby car. With an LS1 Camaro exhaust, Renntech chips, etc it did 385 RWHP and 390 Ftlbs (on a dyno). It's pretty cool for a truck.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 01-23-2008, 03:45 PM
onZedge's Avatar
Originally Posted by shikzachaser View Post
...especially since my wife no longer likes to drive it. "It's hard to shift, it's bumpy, does it need a muffler?"...
You're learning! Now to get out of doing the laundry, put her sweaters in the dryer!!
Edek
'87 924S
'91 535i
Old 01-25-2008, 11:04 AM
We've been married 27 years, I learned the dryer trick a long time ago. I also learned long ago to do a batch of my own cloths and mix the jeans and whites so everything is a nice uniform gray. Laundry is now off limits for me.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 01-25-2008, 11:22 AM
gt350mike's Avatar
I thought I was the only guy that did that............I haven't washed the "family" clothes in 15 years! BTW - It will be 21 years in two weeks!!!
FYI- The same "tactics" works on doing dishes!
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 01-25-2008, 02:11 PM
Agreed w/ the dishes. I clued on that and basicly picked one out of the sink, rinsed it, looked at it and proceeded to load it w/ food. Worked like a charm. I was told I am disgusting and that I should never touch the dishes again.
98 M3 (the wife's)
ML55AMG
03 Eurovan
Old 01-25-2008, 02:25 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
The same thing works for having to change the oil in the wife's minivan. Every time she asks I just say that I will need to get some more tools cause all mine are made for foreign cars. 13 years now and she still hasn't caught on.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 01-25-2008, 03:13 PM
