Quick question about auto trans. indicator
Hello all, I have an 85.5 auto. On my instrument cluster there is PRND21. Should there be a light by it to show what gear I'm in? If so what does it take to fix it? Regards Dietrich
Old 02-01-2008, 12:37 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Yes, there is suppose to be a light to show you what gear you are in. The problem is probably the "paper clip" that attaches the switch to the gearshift. If you look in the center console a wire clip attaches to the gear shift lever and a switch lever. As the shifter moves front and back, the switch lever moves with it and changes the light on the cluster. Bet you want to know the part number of that broken wire don't you? Can't remember but I'll look it up for you.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-01-2008, 03:18 PM
Thanks to LiveWireVooDoo:
Auto Shifter Contact Spring
Tom
Old 02-01-2008, 03:26 PM
