Part Number for AFM
Hello, What is the part number for the AFM that belongs in a 84 944?
Are they interchangeable with other years? Thanks, Ralph
RPorzio 84 944 |
Part number for the 1984 AFM is 944.606.121.00.
From 1985 onward the number changes to 944.606.121.01. I believe they are interchangeable, except for the Turbo and 944S2 versions. |
Bzzzt... not quite interchangeable.
The 84 is only interchangeable with the 82-85/1 AFMs, *unless you change the DME at the same time*...
Good luck, George Beuselinck |
Part Number for AFM
OK, how do those numbers translate to the Bosch part number? Is this a correct AFM for my application 0280 202 084...1984 944? Thanks, Ralph
RPorzio 84 944 |
Should be this... 0 280 202 028
Part Number for AFM
So the 084 will not work?
RPorzio 84 944 |
