hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
Possible to replace Strut cartridge on stock struts???
I was wondering if it is possible to replace the cartridges on stock struts? I see them in the local parts store and was just wondering if that was possible, I can get the needed tools, just wanted to see if it could be done to the stock struts? Thanks Mike
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 02-08-2008, 08:03 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Yes. 86NA & below have replaceable inserts. Your options from cheapest to most expensive is:
Boge
KYB
Bilstein
Koni
Pelican has all of these.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 02-08-2008, 08:35 PM
So I can get them from here or a local parts store, and install with no problms? I did not know if you could. Thanks for the info. Going to get a set of inserts, I just put another used set on, and they are shot. Thanks for the info, that is my next projext. Mike
Old 02-09-2008, 07:27 AM
In the Fires of Hell.....
kdjones2000's Avatar
Hermes,
Look here on Pelican as they have some: http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=&command=DWsearch&description=strut&I1.x=0&I1.y=0&FILTER_944M=ON&FILTER_TECH=ON&FILTER_SUPP=ON&FILTER_ACCE=ON&FILTER_CARE=ON&FILTER_STUF=ON&FILTER_PERF=ON&FILTER_MISC=ON&FILTER_GADG=ON&FILTER_TOOL=ON
Paragon seems to specialize in Koni strut replacements as well...
Cheers,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 02-09-2008, 07:35 AM
THese are the Stock McPhearson struts, Correct? I don't think they are the Konis. Can they be replaced as well? Just wnat to make sure before I spend the cash. Mike
Old 02-09-2008, 09:07 AM
What you replace them with depends on your budget and what kind of ride you want. Prices range from $90 each to $190 each.
Check Clarks-garage.com for the process.
86 Metallic Grey
Old 02-09-2008, 10:17 AM
