West Central Ohio 45380
plyhammer's Avatar
How to tell if a trans is functioning
I have pulled a trans from a parts car and am trying to find out if it is good. Basically, when I spin one side of the trans the other side doesn't move at all. It doesn't matter which side I spin the other side just sits. Am I right in thinking that it is "busted?"
Old 02-11-2008, 06:36 AM
Spin both at the same time in the same direction. Look at the input shaft and make sure it is turning also. Start out in 1st gear, and then check each gear including reverse. You can change the gears with it out of the car. Use a pair of locking pliers on the shifter shaft.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 02-11-2008, 06:45 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Drain the fluid and look for metal.. If you are going to use it, you should change the fluid anyway.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-12-2008, 01:42 PM
I think the other flange is always supposed to spin (the same direction if LSD, opposite if open diff) regardless of whether it's in gear. Someone correct me if I'm wrong.
WARNING: Do not buy from Ron Kirby of Fort Thomas, KY (currently RRRacing1970).
Old 02-12-2008, 02:06 PM
I think you are right but I'm not absolutely sure. That's why I suggested looking for metal in the oil. If it isn't doing that, there should be metal chunks in there.
Tom
Old 02-12-2008, 03:41 PM
Makis's Avatar
Open diff and in gear you spin one flange the other flange will rotate in the opposite direction and the input shaft will not rotate. You spin both flanges in the same direction and then you should see the input shaft also starting to spin. You spin the input shat and the flanges should spin in same direction. I am assembling back my gearbox soon and if I don't see this pattern when all assembled I won't bother to put it on my car.
Old 02-12-2008, 04:17 PM
