3 way adjustable rear sway bar
Hi Guys
I'm putting a 3 way adjustable rear sway bar M030 option on the 968 onto my 944S2 (PN# 94433370101)
Can anyone describe the differences of the 3 positions. I assume the holes nearest the ends of the bar will be the firmest setting? Is that correct?
In the meantime I was going to fit it on the middle (default?) setting.
Old 02-17-2008, 03:35 PM
Custom User Title
Dave L's Avatar
opposite, the shorter the arm the stiffer it is.
Old 02-17-2008, 03:38 PM
Actually that makes sense when you describe it like that. Thanks!
Old 02-17-2008, 04:46 PM
idesign635's Avatar
Send a message via Yahoo to idesign635
On my street car, I run the middle setting.
94 968 Polar Silver/Black, LSD, 6 speed, Short Shift, Kenesis K58's, Adjustable Konis, M030 Swaybars, Dynatech Strut Brace, Design 1 Racing Lower Strut Bar, Air Box Mod, B&B Catback, RS Barn Chip, Big Reds
86 951 Black/Black Lindsey 3" Exhaust, Lindsey DP Wastegate, Lindsey Black Knob, 3 Bar FPR, MaxHP Chips
Old 02-17-2008, 06:03 PM
Is the difference really noticeable or is it very subtle?
Say if someone crawled under your car while it was parked and moved the position by one hole, would you notice that something had changed when you get back in your car and drive off or is it really only at the limit that the differences become apparent when the body is really rolling on it's axis?
Old 02-17-2008, 06:27 PM
flash968's Avatar
depends on the rest of the setup, and how you drive
it also depends on what bar you have up front
Old 02-18-2008, 03:10 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
When I had my 1983 944, a lot of the upgrades I performed were suspension stuff - front and rear sways, front and rear struts, front springs, strut tower brace - and I rarely noticed a difference right away. But the cumulative effect was drastic - I remember driving a stock 944 back to back with my car. My little white car felt like a go kart and the other 944 felt like a Buick (exaggeration, of course, but you get the picture).
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-18-2008, 06:33 AM
I run the middle setting on mine and it does fine. I have heard that if you put it on the stiffest setting, the rear end will skip out a little, or at least on my car.
1984 Porsche 911 Targa
1974 Porsche 911 Coupe- just a tub... for now
Old 02-19-2008, 08:33 PM
