Proprietoristicly Refined
John_AZ's Avatar
Tomiki,
I picked up 8 sets from an ebay seller wall5150 for my spare injectors. He is a regular seller.
Fuel Injector O-rings, Pintle Caps & Seals 8 Cyl Engine - eBay (item 180641856653 end time Mar-26-11 18:59:53 PDT)
In the picture I installed the cap on the injector without the rubber seal. (I can remove it easier). Be careful on the install of the caps. Use a little syl grease or oil.
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-21-2011, 04:58 AM
Overseas
Thanks, John, that looks great! Nice to have 924S owners help each other Smile Wavy
Do you know who manufacture this bulk package or how the quality is? Have you installed and also used them in the car for some time already?
Tomiki
924S (1986)
Old 03-21-2011, 05:57 AM
John_AZ's Avatar
I do not know the MFG. I got an instant response from the seller on other Qs.
I have used them to replace a couple of hats and seals when I was looking for a leaky injector. I plan to use them when I clean a 2nd, spare set of "low mileage" injectors I got.
The injectors, 0 280 150 158 are very expensive new. I do know there are interchanges with slightly different lbs/cc ?? ratings but I guess I am just fixed on the original.
Stan Weiss' - Electronic Fuel Injector (EFI) Flow Data Table
GL
John
"So far----so good"
John
Old 03-21-2011, 06:54 AM
uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
Looks like I will be tackling this problem as well. Injector No 1 has a cracked o-ring and is leaking fuel. Luckily I haven't hard a fire yet. Failed inspection today.
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 03-19-2013, 01:41 PM
uvachief
uvachief's Avatar
Turns out not to be the o-ring. The injector tip is cracked itself. Need to replace the injector.
Sincerely,
uvachief
Old 03-20-2013, 12:53 PM
AFM #725
Gawernator's Avatar
Was it bubbling back out of the injector hole? I had this same issue a few weeks ago. The only o ring that will cause leaks is the top one to fuel rail.
Old 03-20-2013, 06:31 PM
uvachief
uvachief's Avatar
The cap was torn and the injector tip had a small crack.
Sincerely,
uvachief
Old 03-20-2013, 06:45 PM
The only part I have ever used is the fat o-ring, that's what makes the seal in the head. Be careful removing and installing so that the plastic cap is not damaged. A little silicone spray helps lubricate. It also helps when the injector is reinstalled in the head.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 03-21-2013, 05:05 PM
