UH-60 DOCTOR
Send a message via Yahoo to zoogle71
temp II question
hello i have a question and was wondering if any one knows the the value for the diode that is in the wiring bundle at the tempII sensor connector if you expose a lil bit of thewire there is a diode that is soldered in line if any body kow the uF or microfared of this diode plaes let me know
944 lover
ANTHONY RAY DAVIS
Old 04-13-2008, 06:40 AM
Not sure what you are talking about. A Picture would be great. Diodes are not measured in Farads. That's Caps. Most temp sensors use a Variable resistor (Varistor). Diodes are usually rated in Break down voltage.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 04-13-2008, 02:09 PM
