Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
A/C Relay?
so i bought this 1988 944. AC light on the switch lights up, but the a/c doesnt do anything. my question is, if the relay is out will that light still light up?
im trouble shooting. i havent taken a meter yet to it and i have no idea where the relay is.
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 04-14-2008, 05:05 PM
unindicted co-conspirator
looneybin's Avatar
If the freon level is low, the compressor won't turn on.
You can jump the low pressure shut off by touching the terminals with a small screwdriver when the car is running with the A/C switched on.
Most likely since the light comes on that its just low on freon.
It's located behind the drivers side headlight (you need to have the lights up to reach it).
Don't run it for more than 10 seconds unless you are charging the A/C system.
If is comes on, then the relay is OK, if not, then the relay is located with the other relays under the hood, behind the brake master cylinder.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 04-14-2008, 07:25 PM
kuehl's Avatar
General AC troubleshooting here:
http://www.griffiths.com/achelp/achelp2.html
Old 04-19-2008, 05:33 AM
