bpk bpk is offline
two questions
Hi,
I hope someone can help me. I have a 1991 944 S2 and was wondering if Volkswagens G12 plus coolant is suitable for the car?
Also, I have just noticed that the back right of the car rides lower than the left. looking at the wheel, you cannot see the top of it as it is by the body/wheel arch, but on the left side there is a visible gap between the two (please excuse the non-technical description - hopefully you understand what I mean). Is there a simple adjustment for this or does it mean there is a problem with the suspension?
I can insert an image of what I mean, if you need it.
Thanks,
B
Old 05-10-2008, 06:30 AM
1) Yep
2) They all do that. The suspension is never quite centered in relation to the chassis.
Good luck, George Beuselinck
Old 05-10-2008, 08:14 AM
bpk bpk is offline
Thanks George.
On the suspension, would I need to adjust it? The reason I need to know is that if there is an imbalance between the sides, the car will fail the national car test (in Ireland). But I do not know if what I have described means there will be an imbalance.
Thanks again!
Old 05-10-2008, 10:01 AM
