thoen's Avatar
Talking Shifting Problem Solved!!! Thanks!!!
after reading the great posts concerning the transmission and shifting in particular, I decided to follow the advice and change to a Synthetic manual transmission oil. I had some problems with the upper 17mm allen screw but finally was able to get it unscrewed. The buttom screw was another story...it becamed stripped and I was unable to get it off. I had purchased a small pump that screws into the openning of the Mobil One oil (replacing the original cap.) I used that pump in reverse and pumped out the old oil one squirt at a time. it took about thirty minutes and it worked! I pumped in the syntheic oil, replaced the top screw and started the engine. I took the car for a mile or so ride and it was amazing!!! the shifting was like on a new car. I was recently looking for a transmission replacement because of the shifting ( new clutch...not the clutsch!!) and for thrity bucks and two hours of labor, I have a "NEW" transmission. Great guys.
I learned EVERYTHING about my car from Clarks, the Porsche manual...but mostly from you guys. this forum is my mainline.
thanks!!!!
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 06-07-2008, 06:27 PM
