head unit install (with pictures) in 86 944 n/a
This has probably been covered a dozen times already, but here it is again.
Don't own any cassettes and the poor radio reception on my Blaupunkt Monterrey started to get on my nerves. I picked up a Nakamichi MB-VI on e-bay. It's a single din 6 cd changer. The illumination colour is adjustable to match your dash lights. I also picked up a harness adapter for the 944 from crutchfield: ![]() Removed the blau. The only connections i was concerned about was the power plug that plugged into the back of the Blau: ![]() pin 1: (large) ground (brown x2) pin 2: (large) ignition lock (green x2) pin 3: lighting (red with black stripe) pin 4: bridged, antenna (red with black stripe x2) pin 5: blank pin 6: permanent positive (red with white stripe) and the speaker connectors coming from the fader on the dash: ![]() white: front left yellow: rear left black: front right red: rear right I soldered the crutchfield harness to the pigtail on the nakamichi (and used heatshrink tubes to protect the connection). ![]() pin 1: (large) ground (black) pin 2: (large) 12 volts switched (red) pin 3: dimmer (orange) pin 4: power antenna (blue) pin 5: blank pin 6: constant power (yellow) and the speaker connectors: ![]() white: front left green: rear left gray: front right violet: rear right Installed the nakamichi. It was pretty much plug and play and i didn't need to hack up the factory harness. Here's the finished product. It looks stock and matches the dash perfectly.. ![]() ![]()
You have very nice console switches *drool*
Judging from other photos I've seen, a LOT more than the console switches are very nice! That car is in spectacular shape. saifhaq, you weren't in Kingston tonight, were you?
Charlie '99 996 C2 6 speed - Arctic Silver |
I totally agree. From the limited pictures, there is evidence of a very well cared interior. More pics?
Thanks!
No, that wasn't me in Kingston. I was in the GTA all day ![]() I've put up some pics in this thread... Introduction Saif |
Charlie & Saif you guys will have company pretty shortly down there "Newfie 911" name is Kevin " just nab himself a nice 89-S2 same color has Saif in Toronto should have more infos & pics here & RL soon.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Neat. We should have a Southern Ontario get together.
