Removing the OPRV
I'm some trouble unbolting the OPRV on my 87 944S. I tried removing the passenger wheel for easier access, but can't seem to break the OPRV loose. Any suggestions?
Thx |
Use a 24mm (if i remember it right) with a 1/2" universal drive and extension extending out to clear the front bumper and a cheater bar. No need to remove the wheel.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
i'll give that a shot, thanks man! for such a low torque bolt, it's a b*tch to get out. :-)
Pretty sure it's a 17mm. Other than that, just keep trying. The more extensions/swivels you try and use, the let applied torque you will have. Minimize!!
Doug 86 951 BBS, LSD, MBC, Zeitronix stuff, Rennbay stuff, Pelican stuff, Arneworx stuff, and stuff with more stuff. |
Proprietoristicly Refined
Once removed, change both the outside and inside "O" rings on the one piece OPRV.
999-707-144-40-M100 Oil Pressure Relief Valve O-Ring, Inner or Outer, 2 Per Car, 944 (1987-On), Each $2.50. PP also sells the crush washer needed to prevent oil drips and future knuckle bleeding and bashing. =====N-043-815-3-M131 Oil Pressure Relief Valve outer Sealing Ring, 944 All, Each Brand: Fischer & Plath $0.75 GL John_AZ 1988 924s + 1987 924S |
spray some wd40 on it and work it with a wire brush. mine was baked on from the outside and stuck to the block.
Back from Beyond
I had one so bad I changed the housing because that was easier than getting the OPRV retainer off.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
