unindicted co-conspirator
looneybin's Avatar
A/C Compressor elec connection ??
I am trying to replace the A/C compressor & i can't figure out how to unplug the electrical connection from the compressor.
The manual states "unplug the connector"???? ya think???
It appears that it is held on by some type of demonic metal retaining ring from h3ll.
I could just grab onto the plastic plug with some vice grips & use brut force, but the outcome of that approach usually isn't good.
So i thought i would consult with the brain trust here to see if i can get any help as to how this electrical connection unplugs.
any help would be great
Thanks, it's hot here & i would REALLY like to have working A/C
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 07-21-2008, 08:20 PM
Just thinking out loud
mattdavis11's Avatar
It has about an 8 inch lead on it. If you can't get it loose, cut it and splice in a new connector.
Try twisting (loosen) then separating it.
91 FJ80
84 Ram Charger (now gone)
Old 07-21-2008, 10:54 PM
Schumi's Avatar
I did this recently and wedged a screwdriver under the connector I believe and then wedged like hell. I wasn't concerned with breaking it however, but I think it came out just fine.
M
Old 07-21-2008, 11:10 PM
looneybin's Avatar
I thought of just splicing into the existing wire, but the wire on the compressor i am installing has already had the wire cut, so i need to use the existing plug on my car.
Plus i don't want to have a spliced shrink wrapped wire on the bottom of the car exposed to all of the road elements if i can avoid it
Old 07-22-2008, 08:28 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Cut it and splice in a male/female spade connector on each end. It wont be a problem.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 07-22-2008, 08:37 AM
Quality
phoenix_iii's Avatar
IIRC it really is JUST a spade/butt connector...
Cut, splice, heatshrink twice.
Just don't rip it out of the harness if you do try to pull/pry!
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 07-22-2008, 11:36 AM
