Kevins911's Avatar
why do I have 12v at both injector leads??
the connector that clips directly onto the injector, I can't get the car started, on going problem.... so I checked the voltage on the injector harness as per Clark's garage, ignition switch set to on, and I get 12v at both of the points in the connector. Clark's garage says only one point should have 12v, does this mean a bad computer??
Kevin
'73 914 2.0L
Old 07-31-2008, 04:05 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
I would say you have a few bad wires. Fairly common,happened on mine.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 07-31-2008, 05:01 PM
Schumi's Avatar
Clarks said only one should have 12V? is this while cranking or just on? If the car is not running or cranking then I think both are supposed to be 12V. When one gets a signal to fire it grounds out one side.
If only one side was 12V and the other grounded then it would be firing. 12V to both sides = closed (no current drop)
M
Old 07-31-2008, 05:25 PM
The DME actually grounds the circuit to fire as explained above.
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 08-01-2008, 01:31 PM
