Odometer / Speedometer supposed to click?
My odometer bit the bullet long before I got my heap.
Today I got around to pulling the instrument cluster out and working the speedometer/odometer. It appears that the first gear/shaft off where the cable plugs in has "hogged out" the holes the shaft sits in. I added a little bit of plastic in the holes (aka pieces of drinking straw) and the gears appear to work fine, meaning they all spin and the odometer moves, but I have a little bit of binding every now and then and a click like a gear skipping a tooth. Is this normal, like the device to prevent you from running the odometer backwards, or should I be swearing and dig out the magnifying glasses?
Life's short Go fast Have a blast Leave a good looking corpse in a 84 944 |
In the Fires of Hell.....
Pick a couple of your choicest, grab the lens and get to work
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Yeah,
I just fixed it, 5 min after posting. One more plastic shim on the shaft.
Redline Racer
I know what you're talking about. Mine is doing the same thing. I just haven't gotten around to fixing it. So what did you do to fix it?
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
I need to invest in a digital camera.
Basically the worm gear that is connected to the speedometer cable wasn't making contact with the next gear, call it gear B. The shaft that gear B sits on had enlarged the V shaped hole that the shaft spins in. All I did was to insert flattened drinking straw pieces (the only thin plastic I could find) on one side of this V between the shaft and the plastic frame that the hole is in. I did this untill the hole was tight and Gear B was making contact again. The clicking was caused when I did not have the holes on each end of the shaft reduced to the same diameter and one end of the shaft could flop around and skip a tooth every now and then. Eventually with lots of trial and error I got it right and put a dab of superglue on my stack of straw pieces to tack it to the frame.
Is this the case where the speedometer needle bounces like 20/30 mph along with the clicking? If so, you just saved ~$250! That's what the nearest VDO shop quoted to fix the one I had. Good info, thanks!
84 944 |
1984 porsche 944 na
A friend of mine found a place in Fla that did it in 1 day and charged $170 I thought was a bargin to replace the gear inside.But yes a straw is cheaper
Actually I had two bad ones a few years ago. I found a shop in Milwaukee that quoted $120 for the gear replacement (odo not working/no click) and $250 for the other (click/bounce). I didn't want to fool with getting the bezel off of either one so, $120 seemed pretty reasonable to me. If I took it over there, they'd do it while I waited too.
84 944 |
