EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
Look what i found missing, lost bushing...
while under the car i found this...right front. the other side looks okay.
which parts do i need to change out? special tools, suggestions... it never ends
1995 993 C2
Old 09-18-2008, 10:30 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Wrench or deep well socket and a new bushing.
Very simple job.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 09-18-2008, 10:33 AM
That Guy
Techno Duck's Avatar
Replace the center left one also, looks like its got a liberal soaking in ATF and oil . Put some dish soap on the bushings and squeeze it in with a vice for the outter droplink. Pretty simple job.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-18-2008, 10:34 AM
EMBPilot's Avatar
awesome thanks guys.
what do i find the parts named under?
"sway bar bushings"?
=====edit===
heres what i came up with...
951-343-794-07-OEM OEM Front Inner Sway Bar Bushing (21.5mm dia), 944/944S (1987-88)
OR
951-343-794-04-M100 OEM Front Inner Sway Bar Bushing (26.8mm dia), 944/944S/944 Turbo (1987-88)
and...
951-343-793-30-M100 OEM Front Outer Sway Bar Bushing (2 per car, sold per each), 944/944S/944 Turbo (1987-88)
also there appears to be an end cap missing from that side as well.... not sure where to locate that.
1995 993 C2
Old 09-18-2008, 10:47 AM
I've never seen an end cap.
You need to measure your sway bar though so you know which one to order. but yes they will be listed under sway bar bushings.
86 Metallic Grey
Old 09-18-2008, 11:38 AM
That Guy
You will have to measure the sway bar to see what diameter it is. Use a vernier caliper or just use a open end of a wrench.
Jon
Old 09-18-2008, 11:49 AM
flash968's Avatar
that bushing pops out a lot, especially if there are any leaks - bad design - the other bushing where the sway bar mounts to the frame looks shot too
there is no end cap - there is a circlip that fits in a groove on the M030 bars, but not sure about the others
Old 09-18-2008, 11:53 AM
