Dirty little kitty
PorscheKitty's Avatar
Send a message via AIM to PorscheKitty Send a message via Yahoo to PorscheKitty Send a message via Skype™ to PorscheKitty
Porsche Crest New 944 owner...I have some questions...
I just bought an 88 2.5L for 400 bux...well it does run...It didn't until after i brought her home but she runs now...I have a few questions.
First...
The owner said the car had overheated and he parked it. He claims its the water pump. The waterpump doesn't appear to be leaking, however I know it doesn't always have to leak for it to be broken somehow. It's had a new timing belt around 15k ago, but no new water pump and the car has 200k miles on it.
After running for about 10-15 min. the car was already overheating again and I couldn't hear the cooling fans kicking in. Is it mostly likely a water pump issue here if it's overheating that quickly from a cold start?
Also, the car is a little bit rough...sounds more like a little misfire...I haven't been able to check the plugs yet, i just got her yesterday....but are there any common reasons why these engines may miss?
In the higher RPMs, the car sounds very nice but when i let off the gas, it bogs down really low and surges back up, and it will surge a little until it finally evens itself out....would that be an idle control issue?
This is also my first car with an actual oil pressure gauge. The gauge is all the way up when running normally and then under a load, the oil pressure appears to drop. Is that normal?
Also the fuel in it is over a year old and needs to be flushed...That May be adding to the little rough idle....
So any help would be TOTALLY awesome....i'm sorry if I am repeating a question someone else may have asked, but i just needed to throw my list out there. I couldn't really find anything that was the same as mine
Old 09-27-2008, 03:19 AM
Proprietoristicly Refined
John_AZ's Avatar
By the photo it looks like you were smart to have it towed to your home. Will you be doing the repair work? Any prior experience with Porsche?
$400 is a really good price. From what you've said, the repair work should be about $1000 to have it run OK and another $1000 in necessary maintenance (not including clutch) if you do it yourself with the board help.
Welcome to the board.
John_AZ
1988 924S + 1987 924S DD
Old 09-27-2008, 05:08 AM
I would start by seeing why the fans arne't kicking in. There are a couple of ways to do this to see if you are getting power the the thermo switch on the radiator and actually seeing if the switch is working when it is supposed to. Get a haynes manual and look up Clarks garage on the net for repairing your 944. You can drain the gas simply by removing the hose at the tank that goes to the fuel pump at the passenger side rear wheel well. Welcome and good luck with your new find.
Old 09-27-2008, 06:41 AM
Toofah King Bad
Rasta Monsta's Avatar
I'd pull the plugs and see if one of them is bright and shiny from being steam cleaned. If yes, head gasket.
I'd then jumper the two wires attached to the driver's side of the rad, and see if the fans come on with ignition hot. If yes, may be bad temp switch. If no, bad fan relay.
Drain your tank, and refill with Chevron gas. Dump a bottle of Techron additive your first tank or two. Change your fuel filter.
Idle hunting is likely a vacuum leak. Refresh engine vacuum hoses.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-27-2008, 07:32 AM
Just thinking out loud
mattdavis11's Avatar
I'm just going to guess that you need a new thermo fan switch and the catalytic converter or muffler needs to be cleared. Critters like to build nests up in there, and it did happen to my car along time ago.
Timing belts are a must, the mileage isn't the key, it's the age of the rubber.
91 FJ80
84 Ram Charger (now gone)
Old 09-27-2008, 07:34 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Run ALL the gas through it. You can also add a couple bottles of Heat to help. Once it's empty replace the fuel filter and put some new gas in it.
For the idling, it's most likely a vacuum connection (very common) replace the hoses with the kit from lindsey.
Also do the full workup, belts, rollers and water pump. Less then $600 in parts.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 09-27-2008, 11:47 AM
Nobody Special
You would not believe how many cars have overheating problems from nothing more serious than a bad reservoir cap or failure to bleed the cooling system correctly. Start with the easy stuff that doesn't require buying any parts other than a new cap. The rough idle could clear up with just fresh gas and a few cans of Techron. yeah, I'm cheap but avoid buying parts I don't need to replace unless I'm sure.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 09-27-2008, 12:08 PM
John_AZ's Avatar
The 2 blog entries give additional information....
http://forums.pelicanparts.com/blogs/porschekitty/75-my-944-update-prev.html
John_AZ
Old 09-27-2008, 12:18 PM
not to hijack but HOLY BALLS BATMAN, those drain cover rims are spectacular, ive never seen them with the offset like that. Ill give more than you paid for the car right now! just for the wheels. anybody know what those drain covers came off of with that offset.
you got a great deal, not only is it an 88 with the desirable motor, but it runs too
1987 944 n/a
Old 09-27-2008, 01:37 PM
Those look like 928 rims, and they are heavy too!
86 Metallic Grey
Old 09-27-2008, 05:03 PM
1984 porsche 944 na
ballysdad's Avatar
45 lbs each those drain covers just gave mine away and shipped them
Old 09-27-2008, 05:59 PM
Nobody Special
Seriously 45 lbs? Damn, is the navy buying anchors?
Old 09-27-2008, 07:10 PM
Hence why they are called sewer lids....on top of the fact they look like them as well.
86 Metallic Grey
Old 09-27-2008, 07:37 PM
Well, porsche kitty, if you ever decide you want to part with yours, i have CASH waiting. Josh
1987 944 n/a
Old 09-27-2008, 08:54 PM
thekidd's Avatar
Send a message via AIM to thekidd
Tell me if I am wrong. If you turn on the fans for heat/AC, like in my 84, the fans comeon, but if I am not running the fans, she will over heat. That happened once to me when I first got my 84, some coolent on the ground from the overflow hose, but I caught it early as I was working on some lighting. If the fans run, let her run and watch the temp guage, if it stays steady, you'll be allright. Possible thermo swith.
Haha, critters nesting in the tailpipe- seen it, bought the car a few days later (924S) A sight to see when the shop owner started her and saw all the shyt flying out.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 09-27-2008, 11:40 PM
Dirty little kitty
I did a little more checking...I think I'm pretty sure is the H2O pump because I ran her and had the a/c on to get the fans going and she still overheated...If it were a thermostat or clogged radiator, one hose would be hard and pressurized and one would be soft. Neither hose had any pressure in it and I could pop the cap off and there wouldn't be any pressure release. The more i run the car, it idles a little better. I'm going to drain the tank because it has over half a tank of the old gas and I wouldn't be surprised if the guy that had it put 87 in it or Arco or something AHHH. I always put Chevron in my car. I'm gonna put new gas and techron in it.
Those rims are 928 s2 rims...and I like my car and want to keep her sorry guys, I got a steal. lol
Yes I will probably be getting the pump from here.
I will be doing the repairs myself...I'm girl and I love my cars I was a Lexus tech and a Mazda tech...but I have some experience working on 944s and 928s with my dad. My dad has a boxster right now. I like the front engines, though. Thanks so much for the responses. This site is awesome.
Old 09-28-2008, 12:20 AM
These cars are pretty picky when it comes to water. An air bubble in the system can cause an overheating issue.
Raise the front of the car as high as you can and fill it full of water. Open the bleed screw to get all the air out. It's going to take awhile to get all the air out, so be patient.
It would be hard for me to believe that the water pump shaft is being turned by the timing belt, but the impellers are not moving water, if it has enough water. Water pump failures are usually gasket, or water seepage through the weep hole. Catastrophic failure of the water pump would most likely take out the timing belt.
91 FJ80
Old 09-28-2008, 06:46 AM
Dirty little kitty
I'll try that today then, Thanks for the tip. I'll post what happens....the resevoir was empty when I got and I filled that but thats all. Thanks
Old 09-28-2008, 07:40 AM
That Guy
Techno Duck's Avatar
That was probably with tires. Sewer lid are ugly as sin, they are all forged and one of the lighter 16'' wheels available for late offset cars.
There is nothing special about working on these cars, Porsche might be branded on the cam cover but there is nothing complex about them other than a few things where you ask yourself 'what the hell were they thinking?'.
Consider replacing the timing belt, balance shaft belt and water pump before running the car much more. The general consensus is replace at 35-40k miles or every 3-4 years. One of the annoying aspects of these engines is they are interference and a broken belt will probably bend a few valves and leave some dimples in your pistons. You will be able to replace the waterpump at this time and rule that out in the future as a potential cause of the overheating. You can also check the thermostat on the waterpump to make sure its opening..however getting the infamous snap ring out with the pump still on the car is the stuff of legends.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-28-2008, 09:43 AM
Dirty little kitty
Didn't have money to buy coolant today so I tried to figure out if the water pump was actually pumping...
I warmed the car up and took off the upper radiator hose and water wasn't pumping out. I poured water directly into the radiator and then reconnected the hose and this time both upper and lower hoses got hot and hard when the car heated up when before they just stayed soft even when it was hot...sooo I dunno. I'm pretty confused. Seems like a water pump thing to me but again, theres no sign of coolant leaking at the pump. I need to pull the thermostat out and check it.
I just keep hoping its not the pump because I have no money to buy one and I'm DYING to drive it around. Its like torture seeing it sitting there and I can't go down to the beach with the roof off....*tear*
the wheels really do look kind of like sewer lids. lol
Old 09-29-2008, 02:57 AM
Tags
misfire , overheating , rough , surging , water pump
