Engine Life Expectations
I'm new to the board and looking to get a 944. Have had Alfa's and E30 BMW's in the past. Curious about what the engine life expectations are before needing major internal work. For example, looking at 911 SC's, it appears that engines can often go 150k-200k or so before needing top end work. What are the expectations for the 944 and 944S2 engines.
What are price ranges in folks opinions for nice cars that could be used for DD. I see early cars listed from $2500 up to $7000 advertised in Autotrader etc. There is a '84 near me listed for $2800 with records, recent timing belt/water pump and 119k miles. Looks like it could use some interior refreshing but otherwise seems pretty solid. Does this price seem low or in the ballpark. Thanks Len |
These engines can go a long way if treated well. I saw a 951 with 310k for sale that only had the head done once. If you neglect them they will fall apart fast.
Location: In a dumpster behind Albertson's in Los Angeles County
I had almost 300k on my 944NA, and only had the head off once...my fault, overheated and blew the head gasket....car still ran great when I sold it.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
I have 156K on my car and the engine has never been touched (other than belts and WPs). Runs like a champ!
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
Parrothead member
300k on mine all original except for the clutch. ( and couple belt changes..)
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Redline Racer
They're generally pretty durable as long as they are taken care of. On the other hand, I had 150K on my last motor before I killed it and it was using a quart of oil/300 miles with no external leaks. Valve guides definitely needed work and the ring endgaps were 2x out of spec, but I rev it hard alot. The cam and lifters off the old motor are still running fine on the rebuild. The Alusil bores and the pistons are very hard wearing, and the bottom ends are nearly indestructible, except for certain cases usually in racing where it likes to spin the #2 rod bearing. Most people like to change out the rod bearings every 150K or so just to be on the safe side, especially if the car is driven as it was designed to alot. More than anything is just fixing stupid oil leaks, but that depends on how much oil leaks bother you. 200K is pretty reasonable to expect before the head needs a refresh and some new rod bearings installed just to be safe. Oil consumption and leakdown testing will tell you when it needs new rings, which seems to depend a bit, but you'll get at least 150K out of them. The hydraulic cam followers occasionally stick or get lazy, but that's just a matter of swapping in some good used ones.
Any serious prospect should have a pre purchase inspection done at a reputable shop, which should include a leakdown test to give an idea of the state of the motor. It depends alot on maintenance and driving habits, but your estimate is pretty much spot on.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky Last edited by HondaDustR; 12-15-2010 at 08:06 AM.. |
Back from Beyond
Did my rod bearings and HG on my 83 at about 300K miles (not kilometers). There was virtually no wear on the bores and the rod bearings I took out could have gone longer.
They last and last.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
"Dude! You kicked my car.
I've got ~150k (odometer broke so I'm not sure exactly how many) and mine needs some work. I'm going to try and rebuild the top end soonish because it burns oil. But's my car was obviously neglected over the years and if it was properly taken care of it most likely wouldn't need any work.
All Spooled Up
Yep, in most cases, these engines are easily good for 300 grand if properly maintained. The engine in my 951S is almost half way there, and it was never touched internally, except for the late camshaft that I JUST installed. It runs, sounds, & compresses like it was brand new. But then, I do actively use engine treatments in order to insure that it's health is maintained for a long time. You won't fine all of them to be in such good condition, with so many miles though. Lack of proper maintenance, and the occasional defective internal part can easily kill one in less than a hundred thousand. If it is good when it changes into your hands, you should be able to make it stay good for many, many miles to come. As long as you don't get lax with it that is, as they do require quite a bit of maintenance.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Thanks, that is what I was expecting to be the case. Sounds like the basic motor is pretty stout and I should not worry about >100k miles.
I would definitely get a PPI before purchase. Len |
Mine just broke 42,000 miles.. I'm hoping for at least another 42K
![]() Seems if they are used as "normal" cars (not track whores) they can last 200K miles with regular maintenance.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
