87 944
Engine noise
Heres a clip of some of the problems my engine has at rpms above 5k. This is a good day and i didnt capture the exact noise i wanted but see if u can diagnose this.
http://www.youtube.com/watch?v=KVlV3AT9wpU
87 944 |
sounds like a belt scrape..check belts..then check the timing belts too..all u have to do is remove about 7 bolts to take the black cover off..and look for scrape marks...thats what i would do..
87 944
i already have the front cover off to check because one of the rollers looks incredibly close to the belts, is this common. also that didnt catch the sound i was looking for it decided to clear up when i recorded it
or
87 944 |
87 944
what are some fixes for rubbing belts i noticed when i changed the rollers and belts and w/pump that one of the rollers on the timing belt was much larger than the previous. which just so happens to be the one that its most likely rubbing against should i put the old roller back in and see how it fits? any one else have this problem?
btw i have an 87 but no auto tensioner which i have no idea why its gone im thinking one of the po changed things up or it was because it was bought it sept of 86.
87 944 |
Back from Beyond
More often than not the belt scrape is caused by an inner timing cover that's not sitting right. And if your timing belt is too wide, it may be for an S.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Redline Racer
Here's the guard and larger roller.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Back from Beyond
Good photo and great tips!
