Recreational User
Door handle adjust..What's the trick?
The process is simple and well explained. But just how in the world do you pop that little plastic @#$%er off of the post easily? I managed to get the one on the drivers side by sliding a angle head wrench under it and popping it off. Turn, adjust, easy.
There has to be a better way to pop that thing off! I still need to do the passenger side before I wrench the handle right off of the door. Any bent wrench, screwdriver from the side, or something else tricks?
1992 BMW 850i 1984 Porsche 944 gone, but not forgotten 2007 Buell XB9SX 2005 Xterra |
did you take the panel off?
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
Recreational User
The inner panel? LOL, yes. I managed to get the drivers side adjusted and was thinking there had to be a better way. I used an open end wrench slid in between the outer skin and the window rail then under the plastic piece. Now I am trying to do the passenger side. I was thinking I had to be missing something. If I take the extrenal door handle off, can it be accessed that way? I never even tried doing that.
nope, it's a hat trick to connect it, then remove again to adjust, ad nauseum......
not really, worse access and the rod attaches to the door handle and the hinge point is where it usually breaks.
Recreational User
A hat trick is right. I think I had to adjust the drivers door like 5 times before I got it where I wanted it.
Thanks!
1970 Porsche 914 1.7 1987 Porsche 944 2.5 NA |
Recreational User
Here is a great start.
http://www.pelicanparts.com/techarticles/944_door_handle_tuneup/944_door_handle_tuneup.htm Notes: Be really careful when you pry off the panel not to pop out the plastic snaps that hold it onto the door frame. There is a "tray" for lack of a better word under the door handle. Little notch at the front for a small flat tip and it pops off. Has a screw under it that holds the panel on. My outer seals are in pretty good shape so I didn't replace them but this is the time if you need to. My plastic liners were wasted so I picked up some heavy weight garden type plastic from the local hardware store and just cut out new. Little spray cement and almost good as new.
1992 BMW 850i 1984 Porsche 944 gone, but not forgotten 2007 Buell XB9SX 2005 Xterra Last edited by jerry920; 12-02-2008 at 12:45 PM.. |
| Tags |
| adjust , door , post |
