Why can't I get the spark wires off...
of the distributor. Don't they just pull off? (Ready for humiliating replies.)
they do have nubs(?) that hold them on, but more often, its the rubber thats sticking them.
try twisting them until they spin freely then pull....or use a scribe or a very small screwdriver that you've bent at a 90 to both gently pry the boot off the cap (do not pry the whole wire off the cap....just the stuck boot) and to brake the vacuum holding the wire on. |
Are you talking about the end with the spark plug or the other end?
winter-hater club member
because they are stuck.
because the last person to put them on didn't use dielectric grease. try the twist method. then try the pliers/channel lock pliers on them. be warned, they may get damaged.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
no, there is no stupid question imo. the previous owner might have super glued them !! anything can happen !!
nut nynor is right about the grease, just juse a little force while pulling the boot out. i changed my spark plug wires and spark plugs today actually. does anyone have any advice on how to take the distributor cap off?? i am having difficulty because the screw goes in and out and is annoying the hell out of me
KEm 1986 Porsche 944 luxury4play,caranddriver, pelicanparts,944online,reutterwerk,rennlist,renntu be,jpopsuki |
My 944 scares adults
You need to push the screws in and then turn, they're a really weird bent screw that hooks a 90 degree hook under a notch inside the distributor cap...don't worry if it takes a few tries to figure it out, it took me FOREVER, then my dad came over and figured it out in 2 minutes...
1987 Porsche 944 (black) with a 1997 LT1 5.7L V8, BBK 58mm TB, fully ported intake, LT4 Hotcam, Comp Cams 1.6 Rockers, LS1 MAF, Custom Dual 3 inch exhaust through 2 Flowmaster 50 series mufflers 1986 Porsche 944 Turbo, 1989 944 Turbo S engine with K26-8, MBC, knockoff Turbo Twist wheels, test pipe, Ansa cat-back, Chipped (Auto-Authority?) |
The guys give great info here, as you know from being on the site for a few days. But, also check out this site- www.clarks-garage.com Check out the garage shoppe manuel, it will give you a walk through on how to take the D-cap off, and much, much more.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) Last edited by thekidd; 12-13-2008 at 11:56 PM.. |
the haynes repair manual is what i go by usually, but clarks garage is my last resort if i need information right now. thanks lovemy924s !! i still cant get it off and i dont want to try because i dont want to risk stripping the screw so ill use extra caution doing it.
the haynes manual pretty much bites the big weenie. the information here and on clarks garage is much more accurate.
you need to push the "screw" straight in with some force, then turn clockwise. the top and bottom turn the same direction. assembly is the EXACT reverse of removal: you turn the screw counter-clockwise.
One apex at a time
If you want photos of the inside of the cam gear cover with the cap on it. I have one on the bench at the moment. It should make it all clear once you see how the cap clips to the cam gear cover.
