944 S2/968 diagnostics software in va??
Does anybody have a diagnotics tool/ software that will work on a 944 S2 to reset the airbag light in northern VA?? Would you mind lending/renting it out for a quick reset of my airbag light??
![]() Thanks, James |
In the Fires of Hell.....
I think that the later models can only be done at the dealer.... unless someone has the magic tool you are looking for.
Good luck!
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Will program for food
I just reset mine using the info from Clark's garage. Look for the white molex connector (should have a red rubber cover over it) in the right foot well.
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
The magic tool is the Bosch Hammer, an early diagnostic tool. Typically, the 1991 and newer cars are the ones that need it.
As Greg states, Clarks Garage has a nice writeup on resetting the airbag light on the 1987 to 1990 cars. Requires a jumper wire and a watch with a second hand.
Good luck, George Beuselinck |
Did your light stay out after reset?? I wonder why this happens? I am going to give the clarks garage thing a try today. Ill post my outcome. I actually was planning to do that already and could not find that little molex connector until this morning after diggin way up under the dash.
JW,
Initially no. I learned how to read the fault codes (Clark's Garage) luckily diagnosed the issue and bought a part from George at 944 Ecology (quick shipment and nice to deal with). The light is off but I have not had any time driving, working on cruise control issues. As a matter of fact a fellow PCA member has donated his Cruise Control brain (I think mine is bad but not sure). I'll know more this weekend as I hope to have most issues resolved by then.
