LinkBack | Thread Tools | Rate Thread |
I have removed my Stone Guards, but how do I remove the old glue from the body?
Good Morning Everyone,
I have removed my old stone guards from my S2, and was wondering if there is way to remove the old glue that is left on the body prior to putting on the new guards? Thanks Jeff
Jeff 1974 Euro Carrera 2.7 MFI 1966 Corvette 427 Coupe 2002 996 (Daily-Driver) |
3M makes a very nice adhesive remover. It will not harm your paint. You can buy it at your local body shop supply.
Also good for removing the adhesive left behind for hood insulation.
Good luck, George Beuselinck |
In the Fires of Hell.....
Rubbing alcohol, tar remover, Goo Gone have all been tried and work sort of.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Go to Home Depot or Lowe's or whatever...and get some plastic scrapers (in the paint section). Use the goo gone or 3M stuff with those and a toothbrush. I've heard other people recommend erasers and apparently there is some type of a drill bit type eraser that paint/body shops use that gets the glue off pretty easily as well.
I got mine off with a heat gun and plastic scrapers to start then just attacked it with a hard bristled toothbrush and goo gone. It just takes time... |
I decided to delete mine. I tried scraping, heat gun, 3m remover, goo-gone....got tired and cut out some black contact vinyl and covered the gluey mess up. I can't see any defects showing through on them. It was a temporary fix, almost a year ago, still looks good to me.
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy My Website: http://www.TrackPics4Less.com Last edited by 944Spec_bound; 02-06-2009 at 11:58 AM.. |
I agree with the other replies regarding heating up the area with a heat gun or even a hair dryer and using the 3M adhesive remover. GooGone might work also. A plastic scraper will work well to get the adhesive off. I used an old credit card when I took off mine.
