Toofah King Bad
Rasta Monsta's Avatar
Restraint and Good Judgment Needed. . .Please Help!
I have an opportunity to swap an 86 951 drivetrain into my 924S. I will be getting buddy rates on the parts.
Yes, I know the rad subframe will have to go over too, and I am prepared to do that, in addition to installing a 931 header panel for airflow to the IC.
Somebody talk me out of this! PLEASE!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-02-2009, 10:03 AM
Proprietoristicly Refined
John_AZ's Avatar
I am aware you are a master mechanic and someone will post the 951 picture of upgrades from Porsche.
A major issue will be the suspension and brakes after you get it in.
Here is a potential list of issues with just the 951engine you most likely are aware of but may be unknown with the donor 951:
http://www.oz951.com/public/broken.htm
You will do what feels right & GL
John_AZ
Old 04-02-2009, 10:21 AM
Toofah King Bad
Thanks, John. Suspension/Brembos will come from the donor car.
Old 04-02-2009, 12:42 PM
One apex at a time
Dean924s's Avatar
I would get a post 85.5 car and put the 951 stuff in that. The problems with the swap in a 87 924s make it a whole lot less appealing. My 924 ssc project is running in to all kinds of snags as I wanted to use alot of 951 parts and they just do not work with out alot of fabrication.
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 04-02-2009, 05:45 PM
Schumi's Avatar
There have been two people out there that I know of that have swapped 968 3.0's into 924S's. If they can do that... I can imagine that you can handle the turbo swap. Yes it will take time... but it would be worth it.
M
Old 04-02-2009, 05:49 PM
One apex at a time
Dean924s's Avatar
I guess if you dont mind swapping around the upper and lower rad supports and the other bits to convert the nose then go for it. I want ed to use most of the 951 intake and IC in my car and it just is not worth it. I can put a FMIC in it and a custom intake for much less pain and aggravation. DO IT!!!!! it would be a fantastic sleeper!!!.
Oh Ya I have a 931 nose and the grills for sale if interested. Between the two I have $375 in to them and would like to get it back as I am not going to use them. I am going to put the FMIC down low in front of the rad.
Respectfully
Dean
Old 04-02-2009, 06:27 PM
Toofah King Bad
Could you elucidate this a bit more?
Where on earth?!?!
Old 04-03-2009, 01:09 PM
John_AZ's Avatar
Response-Rasta Monsta
"Where on earth?!?!"
Me again.
I looked at your signature and many posts on www.924board.org
John_AZ
Old 04-03-2009, 03:33 PM
One apex at a time
Dean924s's Avatar
There is good info in this thread as to what it takes to put a 951 inter cooler in a pre 85.5 car. I learned a lot from the people that responded. Post #12 has some links to what it takes.
951 Intercooler in a 87 924S
Respectfully
Dean
Old 04-03-2009, 04:16 PM
Toofah King Bad
Ahh, this is a great pic, thanks for the referral. . .
Old 04-03-2009, 08:21 PM
winter-hater club member
nynor's Avatar
shoehorn that engine in there, do an aftermarket intercooler, upgrade the clutch/brakes/springs/shocks, enjoy.
"COOL PRIUS!" - Nobody Ever
Old 04-03-2009, 09:16 PM
Don't forget about the speedometer issue. Your 951 suspension parts won't have provisions for the speedometer and your tranny will. Look into what's necessary to couple that with your 924 instrument.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 04-04-2009, 05:15 AM
Toofah King Bad
Planning on drilling the 951 spindle for the 924 speedo cable.
Old 04-04-2009, 09:20 AM
nynor's Avatar
there is also a fairly cheap electronic solution that someone posted recently.
Old 04-04-2009, 02:54 PM
mistertate's Avatar
Seriously. This has the speedo wiring so you don't have to go drilling into the spindle. All the engine harness wiring and bracketry is mostly there too. I think all you'll need to do for the radiator is unbolt and flip over the lower core support.
And you can get the right amount of tire for the power you'll have
dude
Old 04-05-2009, 02:46 AM
Toofah King Bad
If I wanted a turbo 944, I would buy one. Oh, and I have a solution in mind to get more rubber under the car. . .
Old 04-05-2009, 07:40 AM
