My friends call me, Top
Skytrooper's Avatar
LSD part numbers ?
Does anyone have a quick reference for the LSD part numbers ?
Matt
'87 924S
Old 04-15-2009, 07:42 PM
Greasy Member
many944s's Avatar
Which part numbers are you looking for?
Transmission ID numbers or Porsche part numbers...
The actual Porsche part number for the LSD differential is 951-332-053-05
However....
In all of my transmission endeavors, I have found that there are 2 distinctly different versions of the LSD in these trannys! The standard LSD (found in many of the factory LSD "option" cars and the Turbos) have 4 round openings on the side of the main diff housing and usually have a much lower locking rate. In the few 944S LSD transmissions that I have opened the differential housing has oval shaped side openings, and locks up MUCH more! I have been told that the regular (round opening diff) is a %40 locker, where as the oval opening diff is an %80. whether this is technically correct or not I can not say, but from my experience you cant get the latter ones to slip by hand! it takes considerable force (or a prybay) to get the plates to slip.
Hope it helps!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 04-16-2009, 11:48 AM
Skytrooper's Avatar
Transmission ID numbers is what I wanted...if anyone knows them
Matt
'87 924S
Old 04-18-2009, 05:47 AM
slow944s's Avatar
Just bought an 87 944S about a month ago. How can you determine if it has LSD or not? Thanks in advance....Jerry
84, 944 Silver--Crashed and burned.
87, 944S White--Daily driver
Old 04-18-2009, 08:44 AM
earlr85944's Avatar
http://www.clarks-garage.com/shop-manual/trans-04.htm
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 04-18-2009, 09:51 AM
Skytrooper's Avatar
That helped ! Thanks Earl !
Matt
'87 924S
Old 04-18-2009, 11:13 AM
slow944s's Avatar
Where can I find the option code sticker on my car if it is still on it? Thanks again.
Old 04-18-2009, 11:29 AM
earlr85944's Avatar
no prob
option sticker should be above the spare tire on the back trunk wall
83 944....bye bye
Old 04-18-2009, 12:36 PM
