thekidd's Avatar
Send a message via AIM to thekidd
Speed/ reference replacemnt
OK. Stupid question, but am in the middle of it. Replacing my speed/reference sensors. Got them out, and just received the parst today. I got everything that connects to the sensors- wires, bracket, and the metal that holds the male ends of the wires, all connected in 1 peice. My question is should I take out my old bracket and peices, and replace all the old parts with the very low miled used ones? If so, is there an easy way to take out the bracket? ha, im sure there isnt, but.....
I will wait for a little bit, then I will just take apart the "new" peices and just install the sensor wires. Thanks guys.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 04-17-2009, 11:01 AM
rattlesnakeracing
alantica's Avatar
Porsche Crest Sensor Replacement
subscribing
Hey! A new test case! I haven't done anything other than replace the sensors, so I have no actual words of wisdom other than what you already know from Clark's. Unless your brackets are corroded or really mucked up, why not just save the brackets for a later date?
Adjusting Sensor Clearance
  1. The speed and reference sensors do not normally need adjustment even after replacement. Adjustment is only required if the sensor mounting bracket is removed or the mounting bracket locking bolt is inadvertently loosened.
  2. Remove the speed sensor.
  3. Loosen the mounting bracket locking bolt (6 mm Allen head) and pivot bolt and then re-tighten finger tight.
  4. Glue the 0.8 mm thick washer to the bottom of the sensor.
    NOTE
    I have an clearance adjustment sensor. This is an old speed sensor with the electrical lead cut off to which I have washer permanently glued.
  5. Install the sensor with mounted washer and tighten.
  6. Move the bracket down until it stops again the ring gear on the flywheel.
  7. Tighten the mounting bracket locking bolt and pivot bolt.
  8. Remove the sensor with washer.
  9. If the sensor is to be reused, pry the washer off the sensor.
  10. Install sensor and torque retaining bolt to 8 Nm (6 ft-lb).
  11. Reconnect battery.
87 Charcoal Metallic 944{Proj} 88 White Pearl 944{Daily Driver}
87 Silver Mazda RX-7{210K no rbld} 87 Charcoal Mazda RX-7 GSL{Proj} 88 Gold Met RX-7{Parts} 89 Midnight Black Mazda RX-7 Conv.{Proj}
87 Intl. Scout II{Proj} 99.5 Nissan Pathfinder LE {Daily Driver}
USAF (Ret) GO Blue! - - RattlesnakeRacing - Don't Tread on Me!
Old 04-17-2009, 11:14 AM
thekidd's Avatar
Thanks. I just closed up Clarks speed/ reference sensor page, and looked here, and re-read it again. Well, I will just replace the sensor wires because if were to take the bracket out, I dont know if I will have a "whole day" to do the adjustment on it. I will play it as it goes I guess.
EDIT- I lied about getting the sensors out. I thought that I broke free the speed sensor (one closer to firewall) and would get it out later. I guess I didnt break it. I tried to use a socket wrench, I can get it on, but no room to loosen, just wiggle. I have been trying another way by putting on the 10mm hand wrench (Clarks says 8mm, but wont fit, noe does 9mm) and use a hammer as an extension, and using a 4lb mallet to try and loosen it. Still no go.
Old 04-17-2009, 11:26 AM
callmethewander's Avatar
I have the same problem with the same sensor!
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 04-17-2009, 03:27 PM
If the old sensor is giving you problems to remove, I think you ought to bite the bullet and try to remove the entire bracket. Although functioning properly, I tried to replace mine and found that they were frozen in place. I ended up destroying the bracket to get it and them out... good thing I had the head off the car.
86 951 blk
Old 04-17-2009, 04:22 PM
Army Wrench Turner
Ctan's Avatar
In my experiance it is best to replace all the parts as one (if the bracket, sensor, etc.. all came as one from the same veh) as parts tend to wear with each other, kinda like brake pads with rotors.
A slighty used sensor with it's slightly used bracket will line up better than a used sensor with a new bracket or used bracket from your old sensor.
If you have the parts use em, if not use your old ones. The difference isn't much but it's not perfect.
- '84 944 (Black)
Old 04-17-2009, 04:28 PM
thekidd's Avatar
I got the speed sensor out. I used a neigbors socket wrench with 3 extension on it. I had to cut a zip-tie, but I went straight down to the nut and got it out. Thought about butting in the bracket, but am not all that confident in taking everything out that would be neede to take out to put the sensor bracket in.
I tried to start her, and I got nothing. A real bummer. The car was trying to start, but it just keep turning and turning, but would turn over.
EDIT: I got her up to about 2000 RPMs! Then she quit .
Old 04-18-2009, 12:45 PM
