944 Timing problem
I was driving my 86 944 and the timing gear (#6 in the picture) I believe the bearing went out on it and now it's out of time. I was just wondering if I'm looking at bent valves,piston damage,ect? Never had anything like this happen and was wondering what kind of damage I might be looking at,if any.
Proprietoristicly Refined
WOW, you joined the Pelican forum in August of 2004 and this is your first post!!
![]() Welcome, If what you posted caused valve damage-most likely outcome, you can expect to find at least 2 valves bent, maybe more. Actually this is not serious. If you have a tool box, it is within you ability to get the old head off, send it to member many944s for an exchange. Read his web page for what a good machine shop should do. http://www.benms.com/944head.html The other way to do it is to pay a machine shop to replace at least 2 or more valves, install valve guides, machine the surface and grind the valves and head. Call to see what a shop will charge. Gaskets and misc parts (belts and rollers) required to fix other stuff will cost about $300 to $500. Time to repair and wait for more parts and machine work- about 10 to 14 days If you take your time it is a very doable and simple job. It will just cost a lot. GL John_AZ 1988 924S + 1987 924S |
If---continued...
If your car is in your garage, you should do a leak down test to see if any damage has happened. By showing the roller in the diagram, I guess you have taken off the belt covers. If you say the timing is off, does this mean you can still start the car? I would not try to start the car until you replace all the rollers and get new belts-which you have to do anyway. GL John_AZ |
Did the belt break, or is it rapped around the crank pulley? if your only a few teeth off, and if it did it while the car was at idle i would say you've got lucky. But first see how many teeth you are off by. I have done the HG job and have to say it's alot of fun. I wouldn't recommend doing one on a dohc 928. but it's very do able. As john said you can probably get it done for around $300, I was able to get a HG set for under a 100$ at auto haus. and was able to get my machine shop bill down to under 200$, and that was with 4 new valves, and guides.
dolor et pavor Copyright |
Not starting does usually mean you do have some damage if the roller bearings did fail.
In the next week/months (years) , you will open up the belt covers and know where to start. I just got my issue of Harbor Freight Tools and the leak down tester is $29.99 until 24 August, 2009. A good tool to have.GL John_AZ |
Thanks again....
