What project should I do first ?
Guys I need your opinions. What project should I start first ? I have bought alot of new parts for my car and cannot decide on what project to start with. I work alot and have limited time to do anything but I love to work on my own stuff on limited time. Here is what I have...
Front M474 Koni's (used but good) with springs ( I have to find a compressor to put in bumps) and sway bushings
Stone Guards
Paint phone dials wurth silver.
new injector seals
run new vac lines
change plasic blower cover and install cabin filters
fix bad temp gauge
GET A/C WORKING !!! (this will have to be done by a mechanic)
replace rear hatch pins, hatch lifts.
new auto trans kit (yeah i know ) I dont think its ever been done.
seat switch
72 914 Sold
84 944 Sold
85.5 944 Sold
78 924 (first car) RIP
Old 08-23-2009, 07:40 PM
Toofah King Bad
Rasta Monsta's Avatar
Eliminate vaccuum leaks first. Save koni setup until you have matching rears.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-24-2009, 12:05 AM
Send a message via AIM to Icey1174
+1 on the vac lines. If the injector seals are leaking get them done too.
I agree with the struts too. The rest is in order of your priority.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 08-24-2009, 04:17 AM
Custom User Title
Dave L's Avatar
I would do these first as they are mechanical issues that could leave you stranded at the side of the road;
new injector seals
run new vac lines
fix bad temp gauge
____
Old 08-24-2009, 04:23 AM
Proprietoristicly Refined
John_AZ's Avatar
Hatch lifts---No
Do you want to have the glass separate from the frame?
Injector seals--I hope you mean the seals and hat kits.
You should also do a DIY clean or send them out to be cleaned.
From tech info center above ^^
http://www.pelicanparts.com/techarticles/944_fuel_injector_clean/944_fuel_injector_clean.htm
Vac lines for sure.
You should get new clamps for the bigger lines to replace the pinch clamps.
Use fuel injector clamps or good non-perforated screw type
Check under the big air intake "J" tube for rotted connections.
Order a set of intake gaskets ($5) and prepare to remove intake to do the AOS seals and further vac lines. With the intake off you can adjust the reference sensors. PUT TAPE OVER TDC bellhousing hole!
GL
John_AZ
1988 924S + 1987 924S
Old 08-24-2009, 05:10 AM
adrian jaye's Avatar
you have an alarm right ?
Stone Guards
new injector seals
run new vac lines
fix bad temp gauge
seat switch
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 08-25-2009, 03:38 AM
