In need of an A/C button
Does anyone have a broken/unneeded control switch assembly for a 944, on which the A/C BUTTON (with the snowflake) still functions (by this, I mean that when pressed it stays depressed)? The mechanism inside of my button has broken so it no longer stays depressed. All I need is to replace one of the plastic pieces, which I could get out of another button, so if anyone has a spare SNOWFLAKE button for the 944, I would be glad to buy.
Thanks, Chris
Old 08-30-2009, 01:59 PM
You will have to replace the entire AC switch, which includes the button. You will not be able to replace the parts inside the switch.
To replace the switch, you will have to be adept at desoldering and soldering.
Good luck, George Beuselinck
Old 08-31-2009, 02:38 PM
