How to tell if a Performance Chip has been installed
Hey everyone,
I am unsure if the previous owner had installed a performance chip in my 944. I know that he had considered doing it but am not sure if he has done it for sure. Unfortunately I am no longer in contact with the previous owner so I am curious to know if there is any way to tell if an aftermarket chip has been installed in the DME? I'm guessing the manufacturer would probably install some kind of sticker on the chip itself (I haven't looked yet). Are there certain chip numbers that I can look for or is it just going to be some generic EPROM and there's no way of telling unless it is labeled otherwise?
Thanks.
'87 944
Old 10-25-2009, 06:03 PM
Send a message via AIM to ScoobySteve
Probably the easiest way is to rev in 1st gear and see where the fuel cutoff is. Stock is right around 6500, I believe. Most aftermarket chips raise the rev limiter to at least 6750 or so. This is especially true on 944s as this will allow you to get to 60MPH in 2nd gear and vastly improve the 0-60 time.
-Stephen
00 Boxster S 6MT
03 Subaru WRX w/EJ207 swap
16 Cayman GT4
21 Genesis G70 3.3T
Old 10-25-2009, 06:42 PM
Over 40 victim of fate
stogie25's Avatar
You could pull the computer unit and physically look at the chip. It takes about a half an hour round trip.
black 1988 Porsche 944 (30 years old and getting younger every day)
black 1997 Jeep Wrangler (very modified)
I didn't know cars came in other colors
Semper Fi
Old 10-25-2009, 06:51 PM
All Spooled Up
I don't know about about early models, but I'm pretty sure late ones top out at 7K, with a stock chip. Aftermarket should go above that. If sticker on chip has only printed numbers on it, it is most likely stock.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-25-2009, 07:23 PM
Redline Racer
HondaDustR's Avatar
My stock chip hit the rev limit around 6600 on the tach. My performance chip has a 7000 rpm rev limit, but the tach reads a bit over where 7000 would be when it hits the limit, so maybe my tach is off.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 10-25-2009, 07:33 PM
All Spooled Up
My 87 924S went to 7K with stock chip, and goes to 7.5K with a weltmeister chip. Not sure if it's your tach or not though. There WERE some differences in that model year. For example, mine has the low oil level sensor, but I know that some do NOT have it.
Old 10-26-2009, 09:03 AM
adrian jaye's Avatar
DOES IT DWIVE FASTER, IF IT DoEs DEN IT MAY beee DA chIIPED
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 10-27-2009, 04:50 AM
Certified Porsche addict
The Glademister's Avatar
Another indication would be poor gas milage. If everything else is in order, a N/A 944 should get 28 MPG highway with no performance chip. Same for a 944S. A turbo 944 MPGs is much lower though. I'm having difficulty getting more than 20 MPG highway. My 924S is chipped but I don't drive it on the streets. It's definitely burning through some premium fuel on the autocross course. Of course I've either got the gas peddle on the floor or I'm standing on the brakes!
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 10-27-2009, 05:29 AM
Rogue Tuning
Rogue_Ant's Avatar
Stock rev limits:
The 951 rev-limit is 6480.
Early 944 is also 6480.
The 924S is 6640.
The late 944 should also be 6640.
-Rogue
-Joshua
www.RogueTuning.com
Old 10-27-2009, 12:43 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Best advice so far.
Not only will you know if it has been chipped, then you will also know which chip it is.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 10-27-2009, 01:45 PM
One apex at a time
Dean924s's Avatar
Yep,
Open it, look at it and while you are there run over it with a soldering iron. Cured many little issues with my car this way years back.
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 10-28-2009, 03:24 PM
All Spooled Up
Originally Posted by Rogue_Ant View Post
Stock rev limits:
The 924S is 6640.
-Rogue
Apparently, it is MY 924S tach that is off, then.
Old 10-31-2009, 02:22 PM
Rogue Tuning
Rogue_Ant's Avatar
Most of the 944 that I've been in the tach is off.
-Rogue
-Joshua
www.RogueTuning.com
Old 10-31-2009, 02:59 PM
All Spooled Up
I'm not a believer that performance chips will lower your fuel economy, if you are light on the pedal. I have no problem getting 25+ mpg on the highway (at 75mph) with my 951S. And I know that my fuel injectors are not particularly well matched. When I finally get around to testing the flow of all 9 of the injectors that I have, and install the 4 most closely matched ones, I expect my fuel economy to get even better.
If you are using a 3bar FPR, with chips that are designed for 2.5bar, I imagine that would reduce your fuel economy. A clogged/melted catalyst, bad/fouled O2 sensor, or numerous other things could also be the reason your fuel economy is that bad. Not to mention, a lead foot would also be a contributory factor.
Oh, there IS one other thing - tires. My fuel economy does seem to be lower when I'm running the stock size bridgestone potenza performance tires (and 7/9 inch wheels), which is typically may through october. From november through april, I run a set of 205/60-16 firestone winterforce directional tires on 6/7 inch boxter wheels. Even with gearing being taller due to the larger diameter of the 60-series tires (meaning that every mile measured by the odometer is actually longer), my mpg is higher than it is with the wider performance tires. And I don't feel (or hear) the roughness of the pavement surface like I do with the hard-compound performance tires. At temperatures below 40 degrees (F), performance tires loose any advantage that they have over "standard" tires, anyways. Well, it's time I'm outta here.
Old 10-31-2009, 03:28 PM
your average wrencher...
my 951 gets about 27mpg usually- mostly stock, only a 3 inch exhaust and boost enhancer and my previous car(1987 944s) got 28mpg with a LR chip. its all about your foot!
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 10-31-2009, 04:00 PM
Redline Racer
HondaDustR's Avatar
Supposedly the 944MAX chip has been tuned well so that it doesn't run excessively rich. I didn't notice any drop in fuel milage, and that was with running a cat on FQS set to normal. The chip was tuned with no cat, so I was running rich. It'll probably get a tad better mileage set lean with a cat, and get more power for the same mileage without. I will find both out as soon as I get my motor broken in.
Old 10-31-2009, 09:23 PM
