rporzio's Avatar
Speed and Reference Sensors
Can someone explain to me what the Speed and Reference Sensors (84 944) do? Are they the same and any other info you can tell me about will be helpful. Thanks, Ralph
RPorzio
84 944
Old 11-29-2009, 12:13 PM
Toofah King Bad
Rasta Monsta's Avatar
Speed and Reference Sensors - Checking, Replacement, and Adjustment
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-29-2009, 02:10 PM
rporzio's Avatar
Thanks Rasta, I did see that info on Clark's site, but what I was really looking for is an explanation of what the sensors actually do.
I'll use Clark's directions and tips if I have to replace or test mine.
RPorzio
84 944
Old 11-29-2009, 02:32 PM
One sensor reads a reference stud in the flywheel, and the other reads the teeth on the starter gear I believe. They have magnets on the end that read the metal and send an electrical signal to the DME.
Old 11-29-2009, 02:49 PM
rporzio's Avatar
ok, that's good. What in the world would they have to do with the car suddenly shutting off and then failing to start until hours later when the block has cooled down. These are things that make me go: hmmmm...!
RPorzio
84 944
Old 11-29-2009, 03:02 PM
Toofah King Bad
Yes, they tell the computer the position of the crank, so it can fire the injectors and spark plugs. If the computer gets no signal from the sensors, it kills the fuel pump (something about burning to death in a 100 PSI gasoline fire).
Old 11-29-2009, 03:06 PM
rporzio's Avatar
Are both of the sensors the same, with the exception of the labels? Thanks, Ralph
RPorzio
84 944
Old 11-30-2009, 08:39 AM
That Guy
Techno Duck's Avatar
Yes, sensors are the same part.
Old 11-30-2009, 08:57 AM
Proprietoristicly Refined
John_AZ's Avatar
Ralph,
If you need new reference sensors, there are interchanges for about $70 each. Stay with the sensors that have the silver case on the bottom portion of the sensor. I have seen some aftermarket sensors with a full plastic case.
Techno Duck and a recent TSB I found, said that the turbo starter replacement (now standard) can cause electrical interference with the sensors and cause hard starts.
What do they do? From an internet parts house.
GL
John_AZ
Old 11-30-2009, 10:33 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
making the right connections
Don't overlook the connectors that go to the sensors, they get brittle and fail with age. A bad connector can present a a bad sensor as the brain can't tell the difference. Cleaning and securing the little pins might do the trick and so IMHO it is worth the 10 mins it will take just to check it out.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 11-30-2009, 01:11 PM
Toofah King Bad
I read someplace those connectors were made from a special material called Brittelsheiß.
Old 11-30-2009, 02:00 PM
thekidd's Avatar
Send a message via AIM to thekidd
Originally Posted by John_AZ View Post
Ralph,
Zygmunt Motors: BimmerParts.com has the sensors for $106.56, or abouts, total for 2 sensors. Look at the part number, F6010- 12760, if you change the 0 at the end to a 1, the 1 part number is for the 944's- $100 more for just one! I bought the sensor for a 1979? 320i? series I think, part# is correct so just use that.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 11-30-2009, 03:22 PM
