Speed and Reference Sensors
Can someone explain to me what the Speed and Reference Sensors (84 944) do? Are they the same and any other info you can tell me about will be helpful. Thanks, Ralph
RPorzio 84 944 |
Toofah King Bad
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Thanks Rasta, I did see that info on Clark's site, but what I was really looking for is an explanation of what the sensors actually do.
I'll use Clark's directions and tips if I have to replace or test mine.
RPorzio 84 944 |
One sensor reads a reference stud in the flywheel, and the other reads the teeth on the starter gear I believe. They have magnets on the end that read the metal and send an electrical signal to the DME.
ok, that's good. What in the world would they have to do with the car suddenly shutting off and then failing to start until hours later when the block has cooled down. These are things that make me go: hmmmm...!
RPorzio 84 944 |
Toofah King Bad
Yes, they tell the computer the position of the crank, so it can fire the injectors and spark plugs. If the computer gets no signal from the sensors, it kills the fuel pump (something about burning to death in a 100 PSI gasoline fire).
Are both of the sensors the same, with the exception of the labels? Thanks, Ralph
RPorzio 84 944 |
That Guy
Yes, sensors are the same part.
Proprietoristicly Refined
Ralph,
If you need new reference sensors, there are interchanges for about $70 each. Stay with the sensors that have the silver case on the bottom portion of the sensor. I have seen some aftermarket sensors with a full plastic case. Techno Duck and a recent TSB I found, said that the turbo starter replacement (now standard) can cause electrical interference with the sensors and cause hard starts. What do they do? From an internet parts house. ![]() GL John_AZ |
Automotive Necromancer
making the right connections
Don't overlook the connectors that go to the sensors, they get brittle and fail with age. A bad connector can present a a bad sensor as the brain can't tell the difference. Cleaning and securing the little pins might do the trick and so IMHO it is worth the 10 mins it will take just to check it out.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
Toofah King Bad
I read someplace those connectors were made from a special material called Brittelsheiß.
Zygmunt Motors: BimmerParts.com has the sensors for $106.56, or abouts, total for 2 sensors. Look at the part number, F6010- 12760, if you change the 0 at the end to a 1, the 1 part number is for the 944's- $100 more for just one! I bought the sensor for a 1979? 320i? series I think, part# is correct so just use that.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) Last edited by thekidd; 11-30-2009 at 03:27 PM.. |
